HELP: 348ts passenger door problem | FerrariChat
Discussion in '348/355' started by uptownman, Jun 19, 2007.
  1. uptownman
    uptownman Rookie
    Jun 19, 2007
    6
    Montreal, Canada
    Mark
    Hi guys.
    I'm new to the Ferrari chat as this is my 1st Ferrari ! It took some time but I finally got one! A 1992 348ts Rosso Corsa on black and all original paint!
    Here is my problem: The passenger side door won't open at all! Both the inside and outside door handles don't work. They don't have any "tension" at all compared to the driver side door.
    Is there any solution to this? Is there any way to get to the mechanisms inside the door without the door being able to open?
    I've been able to take the kids for a drive by putting them though the window (dukes of hazzard style), but the wife (or anyone else), still hasn't gone for a ride.
    Please help!
    Thanks!
  2. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
  3. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    #3 Miltonian, Jun 19, 2007
    Hi, Mark. Welcome to Ferrari Chat, and congratulations on your new toy.
    You can open the doors on a 348 from the outside when the window is down, using a long slotted screwdriver. Look down inside the door, at the rear, in the area of the door latch, towards the outer side of the door. If you look carefully, you can see where the cable from the inner door release handle runs straight upward into the latch mechanism. If that cable is attached correctly on each end (chances are that it isn't), then when you pull UP on the inner handle, the cable pulls DOWN on the lever on the latch. By reaching inside with the screwdriver, you can push straight downward on the same lever, and the door will pop right open. I just did it on my own 348 to be sure.
    Once you get the door open, you will need to remove the panels to find out why it isn't opening correctly. Chances are that the linkage has just come unattached.
    The lever on the latch is exactly 6 1/2" down inside the door.
  4. uptownman
    uptownman Rookie
    Jun 19, 2007
    6
    Montreal, Canada
    Mark
    I tried with the screw driver and it's not working....
    I can see the wire and when I move the inside door handle, I see it move slightly. It seems like it's still attached but when I push down with the screw driver, the door still won't open...
    Any other ideas?
    Thanks,
    Mark
  5. w1how
    w1how Rookie
    Jan 12, 2006
    22
    Lancashire,UK
    Marsellus Wallace
    Is the door locked??My passenger door lock stuck on my 355 and it was simply a matter of inserting the key in the passenger door lock and easing it back and forth many times until it came unstuck.
  6. uptownman
    uptownman Rookie
    Jun 19, 2007
    6
    Montreal, Canada
    Mark
    The key only goes in about half way on the passenger door.....from lack of usage I guess.
  7. Houston348
    Houston348 Formula 3
    Oct 18, 2006
    2,297
    i had the same thing happen in mine.. someone slammed the door and it stopped working.. wouldnt open from the inside or oustisde. FoH fixed it for $100
  8. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    What happens when you operate the power door lock/unlock buttons on the console? Does the lock knob on the door go up and down? From your description, it certainly does sound like your passenger door is locked. No wonder it won't open.
    Edit: Looking inside my door again with my flex probe flashlight, I can see the part of the latch mechanism that is moved up and down by the electrical servo and by the key linkage, in order to block the latch so it won't open. It appears to move "up" to unlock. It looks to me like you could make a hook tool with a coat hanger that would lift it up to unlock the door. But it's hard to tell since I don't know what is wrong on your car. It's fairly common for the little linkage piece that connects the lock tumbler to the linkage to snap. That would explain why you can't unlock the door with the key, but you still should be able to unlock it with the electrical button or the manual pushbutton.
  9. uptownman
    uptownman Rookie
    Jun 19, 2007
    6
    Montreal, Canada
    Mark
    I'll try to figure it out..... The doors do lock and unlock. I might just have to bring it to Ferrari Quebec or a local Ferrari specialist.
    Thanks.
  10. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Or from a broken off key by a prior owner (happens).
    If you can see the broken off part, there is a fairly risky way to get the key out with minimal effort (high risk, low effort), which goes along the lines of putting a dab of JB Weld on a blank Ilco key ($2 at your local hardware store) that you've snapped off the first 1/3 to 1/2 of the key such that you have a flat edge to "weld" to the broken-off key inside.
    Insert that new half-key with a dab of JB Weld on the end and leave it pressed in for 30 minutes (suggest the quick-dry JB Weld version). Now slowly pull both key halves out (they should be welded together somewhat).
    The bummer is that if any JB Weld gets inside your lock tumblers...no more lock. Toss it away.
  11. WJHMH
    WJHMH Two Time F1 World Champ
    26,521
    Panther City, Texas
    WJHMH
    I'm running into the same problem right now, thanks Miltonian for the info.
  12. fatbillybob
    Aug 10, 2002
    29,200
    socal
    I would take the lock out and push the broke piece from the other direction
  13. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Smart man!
  14. 348kk
    348kk Karting
    Jan 25, 2007
    106
    I have a simialar issue, this one is on the drivers side, I can still open the door, but I have to use a lot of force to PULL the door out from the outside...try this and let me know.. I know its not a good fix, just temporary. just bring the car to a service center, I'm sure its not an expensive fix... thanks
