Help-355 alternator question | FerrariChat
Discussion in 'Technical Q&A' started by charles dyer, Nov 7, 2010.
  1. charles dyer
    charles dyer Rookie
    Mar 1, 2004
    18
    I am doing a major service. I have a 95 355 with 75K miles. It has the original alternator. Working well and I've never had any problems. While the engine is out, should I have it functionally tested or maybe just go for a re-build. Can they be rebuilt ? If so, who should I take it to ? I live in the Santa Cruz, Calif area.
    I do not drive the car socially, so if it fails I will be in the middle of no where miles from a repair shop.
  2. 335s
    335s Formula Junior
    Jan 17, 2007
    870
    SF Bay Area
    T. Monma
    I have mine done here in San Carlos area-hes been doing my stuf for 25 years....
    PM me and I will gladly give you a number by mid week...he works part time, no Fridays, no Mondays...he has stuff from my Aston Martin DB4/GT, 200Si, and several assorted 250s now...
    FWIW
  3. f355spider
    f355spider F1 World Champ
    18,047
    Always debatable to leave a functioning part alone, but you are at the point where it might worth doing. There are threads here on which electrical parts are best to use, from a reliablity point. The more common oem and replacements are known to give troubles for some. Make sure they use quality bearings. Good luck.
  4. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #4 ernie, Nov 8, 2010
    If you do the work yourself they can be rebuilt for about $50. Here's all the info you need http://ferrarichat.com/forum/showthread.php?t=142329
    If it ain't broke don't fix it. Drive your car until the alternator craps out, THEN fix it. Be sure to read the WHOLE thread before you dig in.
  5. 4redude
    4redude Formula Junior
    Jan 13, 2005
    732
    Fungus Corner
    Brian Keegan
    If your car has not been updated, I highly recommend an additional ground strap from alternator to chassis. Engine to chassis ground connection can sometime be intermittent .
