HELP...355 bell housing/clutch on a 348??? | FerrariChat
Discussion in 'Technical Q&A' started by viperguy, Mar 5, 2004.
  1. viperguy
    viperguy Rookie
    Feb 4, 2004
    22
    Will a 355 bell housing, flywheel, and single disc clutch fit on a 1989 ferrari 348 without any modifications. And if so, what modifications?
    THANKS!
    Jeremy
  2. viperguy
    viperguy Rookie
    Feb 4, 2004
    22
    Bump..... Anyone?
  3. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,860
    The Cold North
    Tom
    No it will not just bolt on in place of the 348 housing. The starter mounting is different. With the 348 you can leave one bolt in place holding the starter. with the 355 all 3 starter bolts must be removed. Also with the 355 there is a large spacer plate between the starter and the trans housing. I'm nit sure about the input shaft lengths either. They may very well be different.
    HTH.
    Tom
