HELP! - 355 drivers Window opening problem | FerrariChat
Discussion in '348/355' started by TrojanFan, Feb 24, 2016.
  1. TrojanFan
    TrojanFan F1 Veteran
    Nov 17, 2008
    5,182
    So. CA & NV
    Peter
    I was driving the 355 a week ago with the top down and the windows up. I went to lower the drivers window and nothing happened. Press the switch and it maybe moves about 1/8" and then nothing. Its always worked with no trouble in the past.
    Is there a "usual suspect" in dealing with window motor problems? Something that fails without warning?
    I'm hoping for some possible solutions before I start tearing the door apart.
  2. R&D
    R&D Karting
    Mar 16, 2015
    168
    Kris
    Did it pop a fuse? If it's anything like my 348 the door loom connector is a trouble spot. If the 355 has the same design, pop it off and clean the contacts.
  3. Terry
    Terry Formula Junior
    Nov 3, 2003
    250
    Cheshire, UK
    Terry
    Try putting the roof back up and latching closed then try the windows.
    Some logic in window opening could have been lost and requires resetting or there may be a problem with the micro switch on the window rail.
  4. WATSON
    23,862
    WI
    Somethings I might check.
    Window switch & connections OK?
    Pull the plug that goes form the door to the frame on the inside door jamb and make sure it is is clean & corrosion free.
    There is a wire harness under the dash that passes by the OBD port. It goes to a black ECU box buried up in the dash. That is the controller for many things including the power windows. Make sure all is clean & connected.
    My problem was in that black box connection. I could reach up there and hit the harness with my foot & make the drivers window come back online <blush> I just fixed that for good this winter. :)
  5. TrojanFan
    Nov 17, 2008
    5,182
    So. CA & NV
    Peter
    Thanks for the suggestions. I managed to get the roof closed. Normally the window goes down some during the top operation but I was able to work it to get it to close. Window still does not go down with the top closed. I have to start checking the connections. The window does move sightly when I try the switch so it appears that it is getting some signal but just not doing much.
  6. TrojanFan
    Nov 17, 2008
    5,182
    So. CA & NV
    Peter
    ll the visible connections look good. What are the next thoughts? Micro switch? Control unit? Motor? Should I assume that I need to remove the door panel to access all of these? What's the easiest way to access the switch inside the door?
  7. WATSON
    23,862
    WI
    Man. I just had my door panel off. Should have done a picture story.
    Let's see if I remember:
    Remove the push lock button (twists off)
    Remove the two screws on the lower door panel at the back of the door
    Remove the one screw on the bottom of the lower panel
    Remove the two screws under the leather cover on the front of the door
    Bump the lower panel forward and it should release and come off
    Remove the two screws holding the upper metal triangle plate at the top front of the door
    Remove the triangle plate
    Remove the hex head screw under the top of the door handle
    Remove the two bolts at the bottom of the door pull handle
    Move the door pull handle out & back and lift up gently to remove
    Undo the small screw inside the door lift handle
    Pull the handle back off the splined shaft being careful not to lose any screws or spacers
    I have a wide door panel removal tool for thees steps...a wide putty knife would work:
    Pop the front part of the door panel off the door frame.
    Work to the top of the door front side
    Pop across the bottom and up the back side
    Lift the door panel away from the frame going up and back.
    Remember, the door switches are still attached.
    Disconnect the switch harnesses. Red to the rear. Black to the front.
    Walk the panel to your work bench.
    I think that was all of it...doing it from memory here at the office.
    Sounds far worse than it actually is to do.
  8. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,272
    CT
    John Kreskovsky
    #8 johnk..., Mar 2, 2016
  9. TrojanFan
    Nov 17, 2008
    5,182
    So. CA & NV
    Peter
    Thanks for the info. Sounds like I have a weekend project.
