Help: 360 F1 transmission issue. Won't start! | FerrariChat
Discussion in 'Technical Q&A' started by mydas, Aug 8, 2008.
  1. mydas
    mydas Karting
    Aug 8, 2008
    52
    Vancouver
    I recently purchased a 2002 360 F1 spider with 11,000 miles on it. I purchased from a Ferrari-Maserati dealer and it came to me fully inspected and with a one year power train warranty. The problem I have experienced from time to time is with starting the car. After following the correct sequence with the key fob, etc. it sometimes will not start and the problem appears to be that it will NOT go in to "neutral" which it needs to be in for ignition to occur. If I manually try to pull both paddles up to bring it in to neutral that will not work. Again, this happens maybe once every 10 start ups or so. The "cure" recommended by the Ferrari tech (since he has experienced this before in 360's) is to wiggle around in the driver's seat while pulling on both paddles to get the car in to neutral. Sometimes, it takes another individual to rock the car back and forth from behind while you do this....eventually, you hear the transmission drop in to neutral and the car is able to start. This seems fairly primitive to me! Has anyone had any experience with this and would you know of a true cure for this condition?
  2. jsanocki
    jsanocki Formula Junior
    Aug 30, 2006
    785
    NJ
    yeah a true cure is take the car back to the dealership you purchased it at and don't take "rock around in your seat" as a solution! This is a 150k car, not a used Toyota.... You have a warranty, make them fix it!
  3. Ramp
    Ramp Rookie
    Dec 2, 2007
    1
    I have the Maserati 4200 which has the same F1 system - been having similar problems although mine will start just not go into gear. Check this - there is a brake switch under the brake pedal. disconnect it and see if the issue goes away. That was my problem - a $2 switch - glad I didn't go to the dealer and fixed it myself. The diagnostics alone would have been a grand
  4. f_the_ASR
    f_the_ASR Karting
    Mar 10, 2006
    149
    Now Mid-West
    Joe Polinchano
    I will bet that the car has a problem with the throwout bearing and flange and or the brake pedal switch and or it needs a new clutch, throwout bearing and flange assy. Take it back to the dealer and have them bleed the clutch and the F1 actuator. Also stand by them and ask for a SD2 printout showing the % of clutch wear. A brake pedal switch error will also be stored in the system. If these two things do not free it up, return the car unless they put in a new clutch.
    Wiggling around in the seat? you have to be ******* i n g kidding me...
  5. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    +1
    I can see it in the owners manual now: "NOTE: if your car won't engage neutral we recommend you wiggle around in your seat. If you have a passenger, they can also wiggle." :D
    [It won't do any good at all, but it might just entertain anyone who's watching you.....]
    Cheers,
    Ian
  6. thecarreaper
    thecarreaper F1 World Champ
    18,054
    Savannah
    these flippy paddle shifter cars are going to be hard as hell to work on when they are 20 years old..... geeze.... i hope you get it fixed.
  7. ferrarioldman
    ferrarioldman Formula 3
    Professional Ferrari Technician Silver Subscribed
    Jun 19, 2002
    1,032
    Summerfield, NC
    Tom Jones
    Make sure that you have the brake pedal depressed when you start the car if the transmission is in gear or if you are trying to select neutral. Check the brake lights to be sure the brake switch is working.
  8. mydas
    mydas Karting
    Aug 8, 2008
    52
    Vancouver
    Thank you for all the suggestions! Very helpful.
  9. fatbillybob
    Aug 10, 2002
    28,957
    socal
    Yes but they both have to wiggle in the same direction or you cancel each other out! Vettes and Porsches look better to me all the time.
  10. mydas
    mydas Karting
    Aug 8, 2008
    52
    Vancouver
    FYI: the car is still in the shop and they have done everything recommended in your reply...they even have a copy of it in the service area, so thank you. It looks like they are going to replace the clutch AND the fly wheel which was not replaced the last time the clutch was replaced....about 170 miles ago. Hopefully this will solve all the transmission problems experienced, so thanks again for the input!
  11. A.J
    A.J Karting
    Dec 14, 2007
    189
    United Kingdom
    Good luck with getting it sorted, keep us posted as to what happens mate :)
  12. traknut
    traknut Karting
    Mar 30, 2006
    121
    I like the guitars.
  13. wahoowa
    wahoowa F1 World Champ
    10,890
    _East Coast_
    Bill
    ...this just happened to me this morning....never happened before. Did you ever determine the cause? I am hoping my situation is a cold weather/low battery amperage "thing". I have been traveling and the car has not been started in two weeks (and I did not have the tender connected....doh...). Opened the door, pump fired up, got in, turned the key, displayed "N", then "All OK" indicator came on and then "1"....brake depressed the whole time. No change when I pulled both paddles.
  14. h00kem
    h00kem Guest
    Dec 15, 2004
    734
    Texas
    Step on the brake pedal 2-3 times before holding the brake pedal down during your shift to neutral. I'll bet it's your brake switch. Because these generall cars sit a fair amount of the switch doesn't get much of a workout to stay limber. If this reliably fixes your problem I would bother replacing the switch unless it gets really bad. Rocking the seat...BS
  15. wahoowa
    10,890
    _East Coast_
    Bill
    ....will check tonight. Crap, it's in the mid 60's today...was really looking forward to a little "therapy" on the drive home tonite!
  16. h00kem
    h00kem Guest
    Dec 15, 2004
    734
    Texas
    the Switches have a tendency to stiffen when it is colder...
  17. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    I don't think this is uncommon. The best solution is to park it in neutral with the parking brake set. I don't like to do this either, so I generally park it in 1st (the 355 will beep at you if you don't). If it won't go into gear, it is the gearbox that needs wiggling, not the drivers seat. Gently rock the car back and forth (easier if you grab the tire as a lever as opposed to pushing on the A-pillar). Mine has only done it once, and it popped right out with a gentle rock.
  18. wahoowa
    10,890
    _East Coast_
    Bill
    ...Finally got a chance to dig into this issue and nothing worked...until I vigorously rocked back and forth in the seat. It went right into neutral and away I went. Seriously, it WAS the switch, several hard presses did the trick; and, yes you guys were spot on (not the seat wiggler), it does seem to be temperature driven. I did notice that if the switch does "act up" while driving you can have a few issues when stopping, as an example, at a light. The car "thinks" you no longer have your foot on the brake and drops into neutral......VERY embarrassing when the light changes.
    As an aside, this forum is absolutely incredible, it is right up there with the landcruiser forum (I had an electrical issue once and Pieter from Moscow shot me back the correct answer in 5 minutes). I just hope that sometime I will be able to help another fchatter.
