Help 550 wont start after clutch replacement | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by hotrodjag, Oct 20, 2009.
  1. Diablo
    Diablo Formula Junior
    Just a stupid question. Did anyone put a prybar on the toothed wheel of the flywheel. I have seen someone do this and move/break the three cotter pins and the timing was now off.
    Just a thought, but yes, check the basics. Spark, fuel and compression.
  2. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    After racing English tractors for decades... and having one lubricate the new garage floor at home....I have a strange love / hate thing going on there.
    I did a kit install on a 3.2 Mondi and noticed a marked improvement as well
    Yes, so long as everything else is good...you can hear the O2 sensor swing very smoothly with no studders. Slight studder on the 2.7s where the O2 sine wave's intersect but that is un avoidable.
    Jim,
    Thanks, I was happy to hear you were going to be involved in an install and am delighted to hear feedback from someone of your caliber. That means a great deal to me.
    Ian,
    we sent the replacement parts over night express AM...did you not receive them Friday AM? The round connectors go to the injector's, I have those if you need them. If you need, I can check on Monday and give you the pin locations for the crank sensors at the Motronic ECU's. None of the under manifold sensors or connections would result in a no start...missing, running rich... but not no start.
    Diablo,
    I could hear compression when discussing this over the phone and was told no spark, no fuel. That would require a medevil level effort to shear those pins off...what the heck was going on with that?! Scarry stuff, must have caused brain damage to identify that problem.
  3. drewprof
    drewprof Rookie
    Feb 5, 2009
    27
    Maryland
    Drew
    Check if you didn't knock the crank sensor out off the way or that you disconnected it from the ignition control module if your particular model has one.
  4. hotrodjag
    hotrodjag Karting
    Sep 7, 2009
    54
    Sarasota FLorida
    Ian Myers
    i did and i even replaced them both .. thank you ..
    car is at the near dealer with and SD .. to see what codes are and to check if the alarm or mercury switch is the problem .... looks like ill be pushing it in to sema :-( ....
  5. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    I'm not going to add to the plethora of speculation already offered.....
    But, I will submit this observation..... Here's what really sucks about this type of "problem". The car was running fine before, right? In all likelihood then, something was disturbed when the clutch was R&R'd. It will turn out to have been something very simple all along --- strained / disconnected wire lead, connector, jostled sensor, pin, etc. The trouble is these can be very tedious to find ---- often things look normal, and the fault cannot be seen directly. Also, it is very tempting to start looking at all sorts of more "sophisticated" possible causes and run a lot of elaborate diagnostic tests.
    So, in the end, after a great deal of thinking, opinions, and effort, you will most likely kick yourself in the head when you finally discover the "stupid little thing" that is causing this problem :)
    Ask me how I know.....;)
  6. hotrodjag
    hotrodjag Karting
    Sep 7, 2009
    54
    Sarasota FLorida
    Ian Myers
    you are 100 % right sir !!!!!!!!!!!!!!!!!
  7. hotrodjag
    hotrodjag Karting
    Sep 7, 2009
    54
    Sarasota FLorida
    Ian Myers
    #32 hotrodjag, Nov 1, 2009
    UPDATE--> well we took the 550 to the nearest dealer (which was kinda a joke ) ne way they came up with the same code that i did .. p0600.... also discovered the passenger ecu was full of WATER ?! well we cant really understand where or how that came about ...because i was just in that area checking relay's and fuses .. so now im on the look out for an ecu ..
    also i know the water in ecu is a problem that needs to be fixed but i dont think it was y the car has the problems in the first place .... IE. thing water was not in there until the car was jacked up out of level.. this probly doesnt make ne since but ????????
  8. finnerty
    May 18, 2004
    10,406
    So.... How in the he** did that happen?! And, is it water, antifreeze / water mix, or A/C condensate? Where is the ECU located? This doesn't seem like something that should be able to happen under any normal circumstance.
  9. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    It isnt on the first page of my checklist....
  10. tazandjan
    39,400
    Plugged A/C evaporator drain hose? Symptom is normally water on passenger side carpets.
    Taz
    Terry Phillips
  11. hotrodjag
    hotrodjag Karting
    Sep 7, 2009
    54
    Sarasota FLorida
    Ian Myers
    well i opened the ecu up and it does NOT look like there was ne water on the inside . but the lower half of the ecu pin outs and cover in corrosion and so is the plug its self !? not looking to good at all ...
    ne body no the best way to clean the ecu plug ? the holes are tiny and i think is going to be very hard to clean them ! hoping that i dont have to depin then one at a time and clean them that way !!!!
  12. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Shoot a photo and send it to me at the shop. There is no easy way to fix what you have...been there, works for a day, maybe two at best and then it will get towed back. Not an area to quick fix as you also have Cat Converters and such that rely on a perfect fuel mixture. The risk is great.
    Poor windshield install is what I suspect led to this. Break out the smoke machine and blow it in the corners of the windshield from the outside. You would be surprised how many we find bad....
  13. finnerty
    May 18, 2004
    10,406
    #38 finnerty, Nov 4, 2009
    If they aren't too bad, they can probably be cleaned up. Otherwise, it is very difficult to effectively clean the contacts (especially the females) on the micro size multi-pin connectors. Too often cleaning them thoroughly results in rubbing off some of the plating ---- which allows them to corrode again quickly (and more or less, permanently). Best solution is to replace the connector halves with new ones ---- which can easily be sourced through places like "Digi-Key", "Newark Electronics", "Waytek", etc. for cheap. The labour is a bit tedious ---- lots of delicate soldering and de-soldering (if they are crimped, it is easier) --- but, it can be done.
    Send it off to Dave ---- he can fix you up :)
  14. finnerty
    May 18, 2004
    10,406
    Gotta love Ferrari !!! What do you want in a car for $250K --- a windshield that doesn't leak ??? -- LOL
  15. BigTex
    79,418
    Houston, Texas
    Bubba
    They DO break........
  16. finnerty
    May 18, 2004
    10,406
    True. It may not be the OE windshield.
    But, for $3K plus...... I'd demand that my replacement windshield not leak either ------- I'm just funny that way :)
  17. SonomaRik
    SonomaRik F1 Veteran
    Still not always the case: Some guys bling out with stereos, cell phone extras, antennas here, Sirus there, you should see the disaster done to my 456....and I don't want to say what Rifledriver found with his smoke machine...sigh.
    Still sorting it out. Never thought to use the machine on the outside corners, thanks.
    IF Purchasing:
    Get a good PPI and take your car through a high-powered car wash before you sign the purchase check over....just saying
  18. hotrodjag
    hotrodjag Karting
    Sep 7, 2009
    54
    Sarasota FLorida
    Ian Myers
    thanks dave i received the brush today
    well as soon as a touched one of the pins it broke off. So now we are SOL and will need an ecu .. ill post up the part number as soon as i get back to florida i will be leaving las vegas mid morning tomorrow ...
    IAN
  19. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    seven months later--- my 550 started today. the ball in cutoff switch was making contact sometimes. cleaned the thing off and car now starts. i hit parking curb hard enough to crack front bumper. Repair shop had a field day with my wallet.
  20. hotrodjag
    hotrodjag Karting
    Sep 7, 2009
    54
    Sarasota FLorida
    Ian Myers
    wow sorry to hear that !!! i even replaced the switch .....
    CARS ARE FUN !
  21. hotrodjag
    hotrodjag Karting
    Sep 7, 2009
    54
    Sarasota FLorida
    Ian Myers
    the 550 started yesterday .. come to find out that the wire that lets the 2 ecus talk to each other was corroded and broken off ... right where it goes in to the plug for the rights side ecu as well as the pin comming out of the ecu was broke off as well ...
    long story short MAKE DAMN SURE that your wind sheild does not leak !!!!!!!!!!! ill try and post up pics today
  22. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    wow i am impressed. congratulations. BTW did your car learn any new words?
  23. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    I also had a corroded ECU on the RH side a few years ago. At the time I wondered how it happened. Now I know. Glad you finally solved your problem.
  24. JazzyO
    JazzyO F1 World Champ
    Jan 14, 2007
    12,161
    The Netherlands
    Onno
    Good to keep in mind. Thanks!
    Onno
  25. hotrodjag
    hotrodjag Karting
    Sep 7, 2009
    54
    Sarasota FLorida
    Ian Myers
    lmao you know it lots of four letter words
