Help! 91 TR dead? | FerrariChat
Help! 91 TR dead?
Discussion in 'Boxers/TR/M' started by IvoryAuto, Feb 26, 2025.
  1. IvoryAuto
    IvoryAuto Rookie
    Feb 25, 2025
    5
    EZ
    1991 TR Euro spec
    No horn, no dash lights, car is completely dead but was working fine a few days ago? I got a click click before it started up-ran perfect, then went to move it and now key is completely dead? No power to the dash cluster, no power to the ignition switch, tested the fuse box and there is power to the fuses? But the actual negative and positive to battery are completely dead not even a spark when I touch the battery cables to the terminals. Swapped out relays to starter- took out battery charged it- still no juice! could this be caused by the protection C relay? Where could the power break be?
  2. TestaDDS
    TestaDDS Karting
    Sep 6, 2015
    87
    France
    RM
    Hello IvoryAuto, if I may ask, have you checked what's happening with the ignition switch (Neiman) ?
  3. IvoryAuto
    IvoryAuto Rookie
    Feb 25, 2025
    5
    EZ
    No this just happened looking for help
  4. lagunacc
    lagunacc F1 Rookie
    4,326
    The symptoms for the C relay seem different, starts and dies.
  5. IvoryAuto
    IvoryAuto Rookie
    Feb 25, 2025
    5
    EZ
    I have power to all my grounds!?? What can cause this?
  6. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,648
    Argent/Brasil
    Guido
    Short in the batterie ?!
  7. IvoryAuto
    IvoryAuto Rookie
    Feb 25, 2025
    5
    EZ
    My ignition switch has power to all contacts?
  8. Steve Magnusson
    26,716
    No.
    Your headlights should work even with the key not present in the ignition switch. Have you cycled the battery cutoff switch a few times on-off-on-off-on? Otherwise, it has to be a bad connection in the primary battery wiring.
  9. ago car nut
    ago car nut F1 Veteran
    5,495
    Madison Ohio
    David A.
    I have removed the cut off switch on my TR and cleaned the corrosion.
  10. IvoryAuto
    IvoryAuto Rookie
    Feb 25, 2025
    5
    EZ
    It was the cut off switch! Thanks to all! I had to remove and clean it. :cool:
  11. djs308
    djs308 Formula 3
    1,131
    Long Island, NY
    David S.
    Interesting... Same issue happened to my Mondial a number of years back. Drove it just fine for about half an hour. Parked for a bit. Went back in to drive home, but got the click-click, no-start. Battery is always on a tender. The culprit was the same as above—corrosion in the battery cut off switch. Just another interesting quirk with the car!
    turbo-joe likes this.
