HELP! AC button not working in 348 | FerrariChat
Discussion in '348/355' started by 348kk, Mar 14, 2008.
  1. 348kk
    348kk Karting
    Jan 25, 2007
    106
    HI, just want to get some advice on the AC unit... one day it was working all fine and the next day, the AC won't turn on.. I press the AC button and nothing comes on, not even the little green lights.. let me know.. is there some contacts or relays that I can clean? thanks
  2. Standig
    Standig Karting
    May 13, 2002
    152
    Spring Hill, Fl
    Stan DiGuiseppi
    there is a a/c fuse in front luggage compartment under the top access panel / pull fuse and reconnect
    should solve your problem
  3. PassionIsFerrari
    PassionIsFerrari Formula 3
    Aug 15, 2004
    2,454
    That fuse is notorious for breaking...and it isnt marked either...it is in the top corner under the front hood on the passenger side...I think you have to raise the black trunk liner to expose it...most people splice a new one on if it the original because it is not uncommon for that fuse to burn up... New fuse will put you back in biz!
