Help.... Alignment question | FerrariChat
Discussion in 'Technical Q&A' started by Rollers, Jul 20, 2005.
  1. Rollers
    Rollers Karting
    Apr 29, 2005
    74
    S.W. Fla
    I just replaced the crappy Factory metric rubber on my much loved Mondy 3.2 with a set of the Chromed 348 wheels and new P-Zeros! I am not sure what specs to align the wheels to. As it is now it looks as if the camber is off..... any thoughts from those that have been here already..?
    thanks for any help you can offer
  2. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    The settings for the metric wheels are :-
    Front camber -0° 20' to -0° 40'
    Rear camber -1° 20' to -1° 40'
    Front toe-in 1.5mm to 2.5mm
    Rear toe-in 2.0mm to 3.0mm
    Front tyre pressures 2.4 bar (cold)
    Rear tyre pressures 2.4 bar (cold)
    The Mondial 3.2 that had non metric wheels and was fitted with Goodyear tyres had the following settings :-
    Front camber -0° 30' to -0° 50'
    Rear camber -1° 30' to -1° 50'
    Front toe-in 2.0mm to 3.0mm
    Front tyre pressures 2.6 bar (cold)
    Rear tyre pressures 2.7 bar (cold)
    Castor remains the same.
    As both sets of figures are quite close I would use the latter settings as a starting point and then see how the car handles.
  3. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
