Help! - Alternator Tension Pulley Bearing removal | FerrariChat
Discussion in '348/355' started by TrojanFan, Jan 12, 2014.
  1. TrojanFan
    TrojanFan F1 Veteran
    Nov 17, 2008
    5,149
    So. CA & NV
    Peter
    #1 TrojanFan, Jan 12, 2014
    As a follow up to my smoke from the engine compartment thread, I'm under the car, cut the AC belt and it is fairly obvious that the AC belt tension pulley bearing is bad. My question is how to properly remove it? I removed the nut and washer and the thing isn't coming off. I've used a small pry bar to try and pop it forward but it isn't moving. I don't want to bend or break anything. Anyone have any suggestions on how they removed it? Does the support bracket need to come out with it?
  2. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,007
    Indio Ca/ Alberta
    Grant
    Not sure i understand I did not think there was a tension bearing on the ac I thought you move the compressor within the slotted arm. I know on mine the bolt was mega tight need antisieze and heat.
  3. TrojanFan
    Nov 17, 2008
    5,149
    So. CA & NV
    Peter
    #3 TrojanFan, Jan 12, 2014
    Error on my part. Its the alternator side not the AC. Anyway, here's the update. I worked the pulley back and forth some more with a small pry bar and it popped off. In the photo you can see the burn marks from where the belt was melted from the friction of rubbing on the seized pulley. Next I need to pop out the bearing and replace it.
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,423
    San Carlos, CA
    Mitchell Le
    Celebrate that it is not the water pump. Good luck.
  5. TrojanFan
    Nov 17, 2008
    5,149
    So. CA & NV
    Peter
    Bearing went on fairly easily but the belt is another story. After fabricating a tool out of a coat hanger, I was finally able to loop the belt around the water pump pulley, however after about an hour of futzing around attempting to get the belt around the tensioner, I gave up for the day. I have the tensioner pulley as loose at it can go and I still can't get the belt around it. Maybe the wrong sized belt? The original one appeared slightly larger but I thought the minimal difference could have been from stretching.
  6. TrojanFan
    Nov 17, 2008
    5,149
    So. CA & NV
    Peter
    Anyone know how I can re-label this thread? AC tension bearing is incorrect and should be Alternator Tension Pulley bearing.
    In any case, I have been struggling to get the belt over the newly installed pulley/bearing assembly. I notice that the belt that I was sent is 2mm smaller than the one that I took off. I don't know if that is enough to make a difference but I was having trouble getting the belt on.
    Unfortunately this is where it took a wrong turn. In an attempt to loosen the pulley assembly as much as possible, I inadvertently snapped the adjustment screw in half. This now required me to pull the pulley assembly off and order a new adjustment screw. Both of my local dealers are out of stock so I ordered from Ricambi who, in turn needs to order from Ferrari in NJ. Not a big expense, less than $10 including the shipping, but it postpones completing the job and getting my car back on the road by another week.
    Just an FYI for anyone who has not replaced the alternator belt before, the adjustment screw needs to be turned to the RIGHT to loosen the pulley, not the left (Rather counter intuitive for those of us used to loosening to the left) and when it starts to get snug make sure that you stop or you will end up with a broker screw.
  7. plugzit
    plugzit F1 Veteran
    7,760
    Redondo Beach, CA
    Bruce Bogart
    2mm is a lot for that belt.
  8. TrojanFan
    Nov 17, 2008
    5,149
    So. CA & NV
    Peter
    The belt came from GT Car Parts and they insist that the 1250 belt that they sent me is the correct size. The 1252 must have been put on the last time it was replaced and whoever did the job went with a slightly larger belt to make it easier. Just goes to show that I should have pulled the number off the old part first.
  9. Steve Magnusson
    26,606
  10. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,007
    Indio Ca/ Alberta
    Grant
    Mine was tight as well what I did was put the belt over everything except the alternator then turn the alternator over since it is the easiest part to get at. That's how I did it. You could also warm the belt up in your over at 100 f to soften it a little. Also as said earlier if you loosen the alternator bolts you can get a better angle this helps as well.
  11. TrojanFan
    Nov 17, 2008
    5,149
    So. CA & NV
    Peter
  12. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Send Rob a PM to rename the thread
  13. Steve Magnusson
    26,606
    Can't comment on that directly on that (as I don't have a 355 to fondle), but, from the scale of the parts in the drawing, it appears as though when bolt #11 is in the bottommost position in the slot, the pulley would not be completely obscuring the top #16 nut, but the drawing doesn't really convey what the relative access (due to other surrounding items not shown) is, or isn't.
  14. Dino Chang
    Dino Chang Guest
    Dec 29, 2012
    772
    #14 Dino Chang, Jan 18, 2014
    Because I know this belt can be tight the way I have done them is this.
    I remove the alternator. Then I place the tensioner holder onto the block, with the alternator of the top nut and stud is easy to get at. Even though the tensioner is on the shaft I leave the center nut of.
    I then replace the alternator. Then I pull the tensioner/bearing towards the end of the tapered shaft ( towards the fuel tank), thus allowing enough room to place the belt around all the pulleys including the tensioner.Then I slip the Bearing/tensioner back up the shaft and put the center nut on.
    Being that you are under the car now, you will see what I mean about the tapered shaft that the tensioner bearing sits on.
  15. TrojanFan
    Nov 17, 2008
    5,149
    So. CA & NV
    Peter
    Ok, new adjustment screw has come in and I'm back under the car fighting this belt. Does the alternator need to be removed? If I just remove the bottom alternator bolt with the spring on it will it pivot inward to allow the belt to slip on? Is this spring bolt going to give me problems?
    Any other way to get this belt on without removing anything else?
    I've rebuilt automatic transmissions that were less hassel than this simple belt. I can't wait for one of the hard repair jobs!
  16. plugzit
    plugzit F1 Veteran
    7,760
    Redondo Beach, CA
    Bruce Bogart
    One of the more unpleasant jobs on the 355. Just think of it as an opportunity to use words you're not allowed to use elsewhere.
  17. Dino Chang
    Dino Chang Guest
    Dec 29, 2012
    772
    :( It's not a hard job.
    Besides the alternator will not swing forward if only the bottom bolt is removed.
  18. TrojanFan
    Nov 17, 2008
    5,149
    So. CA & NV
    Peter
    ok. After what has been about 8 hours and 2 weeks of waiting for parts, the new tensioner bearing, pulley and belt are back on the car. Removing the alternator did not seem like a good option to me. The lower bolt came off ok but the upper bolt was going to be another knuckle busting swear fest that I was not about to endure.
    I was able to push up on the pulley and maneuver the pulley bolt enough back and forth to angle it and slowly work the belt up and the pulley on.
    In the end after 8 hours, I'm not sure if the money saved and satisfaction of doing the job was worth the time spent. I'm a Ferrari novice but fairly competent with automotive work. To do it all over again on what should be a simple job I don't know if it was worth my time. Next time I'm sure I could do it faster (and I wouldn't bust the adjusting screw in the process) but for the time I just spent, it probably would have been more effective to have brought it to a competent shop and had it back in a few hours.
    One last question for the brain trust. I don't have any kind of belt tension gauge. Is there a good rule of thumb or visual clue as to the proper tension for the belt? I'm not looking to do this all over again anytime soon.
  19. Dino Chang
    Dino Chang Guest
    Dec 29, 2012
    772
    Congrats on a job well done :)
    To clarify why I suggested removing the alternator. This was not to replace the belt, but to get at and tighten the top nut of the tensioner bearing holder, because you were having problems. Then once the holders on the alternator is replaced. I have developed the nack of that top alternator bolt.
    Regarding the belt tension, my experience of doing this over the years tells me when its correct. I use the 90 degree twist to give me right tightness. But no doubt some one who hasn't done the job before especially with the engine in the car, will suggest buying a belt tensioner gauge. Good luck getting that onto the belt while its on the car :)
    Well done never the less, its a great feeling knowing you have done it your self.
  20. GerryD
    GerryD Formula 3
    May 5, 2010
    2,439
    North of TO
    Guido
    Dino has it right. The alternator has to be moved and its not that hard....the 2nd time around. That bearing lasts a long time before it ceases. You have to listen to your car when driving steady on the highway. You can always hear it before it goes. It will make a throaty hum coming from right behind you and it will do that for a few years before it ceases.
