360 - Help! Alternator Wire Nut Size? | FerrariChat
360 Help! Alternator Wire Nut Size?
Discussion in '360/430' started by Virulosity, Mar 2, 2022.
  1. Virulosity
    Virulosity Karting
    Jun 26, 2017
    162
    Orange County CA
    Rob
    I was driving the car today and the battery light came on. I pulled into work and noticed that the heavy gauge wire has come loose from the alternator. It looks like the nut spun off. Do you know what size? Maybe I can find one at a local auto-parts store.
    Thank you!
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    If you mean the power output cable from the alternator, it will probably be a metric course. Common sizes
  3. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,423
    Santa Clarita, CA
    I’m fairly sure it’s gonna be metric. Buy a handful of different sizes, they’re only a few penny’s each. Try to get a stop nut that fits so it won’t come off again.
  4. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,112
    Josh @jtcarprojects
    8mm or 10mm
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Generally standard metric nuts are metric coarse, there is also a metric fine but not common
  6. Virulosity
    Virulosity Karting
    Jun 26, 2017
    162
    Orange County CA
    Rob
    Thanks guys! On closer inspection it was a failed crimp! I took the chance and drove the car home on battery and it made it! 12 miles....
    Qavion likes this.
