Help....battery flat | FerrariChat
Discussion in '348/355' started by lotusk, Sep 23, 2014.
  1. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    #1 lotusk, Sep 23, 2014
    I kept the keys in my 355's ignition for about ten days with my battery tender connected as usual in the engine bay and now battery flat.
    When i disconnected and reconnected the tender there are a load of relay switch clicks happening, the hazard lights are trying to flash and the door locks keep trying to open and lock.
    What to do?
    I want the tender to charge up the battery but concerned about all the above happening!
  2. WATSON
    23,926
    WI
    Wow. My battery died a couple winters ago and it never acted like that on recharge.
    Maybe try an exorcism?
  3. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Shut off the battery switch and keep the tender on the battery for a few days.
  4. RS6bird
    RS6bird Formula Junior
    Mar 20, 2006
    316
    Lisbon, Portugal
    RS6Bird
    +1 great suggestion. Many electrical gremlins and adjustments can be solved by turning the "power" off switch on the car.
  5. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Thanku
  6. bosshog8
    bosshog8 Formula Junior
    Mar 13, 2011
    448
    Pinelands NJ
    Demetrius
    I would check the electrolyte level before continuing a charge. I know most batteries are maintenance free and no one thinks of that any more but they really aren't maintence free unless they are a dry cell.
  7. plugzit
    plugzit F1 Veteran
    7,792
    Redondo Beach, CA
    Bruce Bogart
    I've killed a couple of batteries by leaving the key in the ignition. Arrrrrgh.
  8. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    How does leaving the key in the ignition drain the battery even when on charge?
  9. plugzit
    plugzit F1 Veteran
    7,792
    Redondo Beach, CA
    Bruce Bogart
    I do not know.
  10. BOKE
    BOKE Beaks' Gun Rabbi
    33,965
    600 East Fremont Street
    Lucky
    If the battery is more than two years old, replace it with an AGM battery.
    Don't waste you time if the battery is more than two years old.
  11. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Understood
  12. phrogs
    phrogs F1 Veteran
    7,358
    Kzoo Michigan
    Control, alt, delete the computers!
  13. spaghetti_jet
    spaghetti_jet Formula Junior
    Jan 5, 2005
    949
    Europa
    Bob
    The battery is simply dead flat. This exact scenario has happened to me a few times when I've accidentally let the battery go dead. I have separate GPS/GSM tracker, alarm and immobiliser that have a relatively high quiescent drain between them, if I leave the car two weeks without driving or putting the tender on it will do exactly what you have described with all the clicking and flashing of lights etc.
    The best thing to do is simply charge the battery at least overnight with a proper full-size car battery charger. There will be no repurcussions, everything will work fine once the battery is fully charged.
    I have never successfully recovered the situation with the battery tender alone because on my car (due to the security accessories) the quiescent drain alone is like 50% of the tender's max output. I worked out once that it would take 5 months to fully charge the battery from empty to full on the tender alone.
  14. Madaboutred
    Madaboutred Formula Junior
    957
    Athens Greece
    Aris Thomazos
    Above post is correct.
    You can not revive a dead battery on a tender. (Most of the times)
    One good thing to check is if the cells are still "alive" meaning that they are flat and have no deformation on their surface.
    You can inspect it through the electrolyte slot on the top.
    But if the battery is maintenace free, this does not apply.
  15. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    FYI. I killed mine by leaving the obd reader plugged in as well. I always drop the key on the floor so not sure if that causes a drain.
  16. vracer
    vracer Formula 3
    Jun 23, 2014
    1,098
    NorCal
    Richard
    I agree w. others - AGM is the answer, but the question that I never even thought about is the key in the ignition causing battery drain.
  17. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Yes
    Battery not coming back to life after 2 days on tender
    Bought new one
  18. Bertil
    Bertil Karting
    Sep 8, 2012
    199
    Stockholm Sweden
    Bertil Palmblad
    I don't know about the 355, but my 348 has actually 4 positions for the key.
    1: when you put in the key. Nothing happens.
    2: When you turn the key about 5-10 mm, the ABS bulb lights up and then goes out.
    3: All bulbs light up.
    4: You crank the engine.
    In position 2, you will flat the battery as nothing indicates that you are sending power to the ABS unit. More power than a small charger will supply.
    Don't ask me how I know....
    Bertil
  19. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Not surprising, battery tenders are not meant to be able to charge a dead battery. A "real" battery charger may have worked better.
  20. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Good advice
  21. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Yup....maybe my mistake
