Help! big brakes without splash shield = no brakes in the rain!!! | FerrariChat
Discussion in 'Tracking & Driver Education' started by chrismorse, Oct 24, 2014.
  1. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    Has anyone else removed the backing plates, to better cool the brakes and found that when it rains, the brakes don't work for a scary few seconds???
    We are talking major pucker factor here, (the drivers seat suchion may never be the same again)!!!!
    Do I have too hard of a compound, (Pagid R4-S).
    I have to drive the car 250 miles to SF likely in the rain for a medical appointment, and if I can put on a softer pad to act more quickly, I will do it.
    The irony is staggering - - I put F-50 brakes on the front and went to great lengths to install a full floating 360 rear brake, complete with parking brake and Tilton adjustable bias , only to find that when wet, I had better start braking a half hour before I need to stop - once hot everything is as god as you could hope, but cold and wet, I would better off opening the door and dragging my tennis shoe, (leather drivers shoe- of course :)
    This is a fairly humbling moment, particularly considering the amount of time and effort I have put into trying to really do it right.
    TIA for the input,
    chris
  2. Todd308TR
    Todd308TR F1 World Champ
    Nov 25, 2010
    11,074
    LA
    Todd
    Yes, happened with me on my C6 Vette with a front BBK.
  3. chrismorse
    Feb 16, 2004
    2,150
    chris morse
    Hi Todd,
    Were you able to get them to work cold and wet? Swap pads or re-install splash shield??
    chirs
  4. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,892
    Richmond
    Pete
    Put on drilled rotors or pump the pedal once before braking to remove the water. Pad compound won't do anything.
  5. fatbillybob
    Aug 10, 2002
    28,986
    socal
    What exactly happens and what is your set-up?
  6. Todd308TR
    Nov 25, 2010
    11,074
    LA
    Todd
    I had slotted rotors, cold they worked fine, but the first heavy rain I almost rear ended a car at the light. Not even Stoptech had a good answer as to why. Pedal was mushy too, but in the dry the pedal was hard and the Stoptechs very responsive.
  7. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,958
    MO
    Omar
    On the street I tend to avoid overly aggressive pads for their lack of initial bite, particularly in rain or extreme cold (the later being a particular concern for a more northern climate).
    As a sanity check I would swap to proper street pads to make sure its not simply a hard compound + rain + cold issue.
    If it persists, a more extensive work up of the braking system is in order.
  8. chrismorse
    Feb 16, 2004
    2,150
    chris morse
    #8 chrismorse, Oct 26, 2014
    Here's the set up:
    Front discs 355x32 drilled brembos, (used, but turned and zinc washed) on Girodisc custom hats with brembo floating pins, 44-40 Brembo, (F-50) calipers on Girodisc custom brackets, stainless brake lines.
    Rear: 36/40 Brembo calipers moved to the front of the upright, by spot facing the upright and helicoiling. Custom cnc parking brake caliper brackets mounted in the stock caliper location, utilizing the 360 parking brake caliper and stock cable actuation. (they work just as well as the stock ATE parking brake),332x28 new drilled brembo discs on Girodisc hats & bobbins. more stainless lines.
    Wilwood 1-1/18 tandem master cylinder machined to mount to the stock booster.
    Tilton Lever style bias adjuster.
    With the 14 and 13 inch discs and the larger caliper pistons,The front to rear brake torque is biased a few percent more to the rear and the higher torque means that the stock prop valve would come in to late, so I installed the tilton unit and the balance is great.
    Cold, the brakes work fine, only a bit more pedal effort BUT in a driving rain, (pun intended), unless the brakes have been warmed up and dried off for several seconds, there is almost no retardation.
    I have tracked the car a few times at thunderhill and the brakes are rock solid, dead linear, without a whif of fade. The pedal effort is noticeable less with very good controllability at lock up.
  9. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,892
    Richmond
    Pete
    Water gets on the rotors and push the pads back so you have to pump them once or twice to clear the water and push the pads back out to the rotor - that's why they feel soft. Drilled rotors help by not allowing the water to have an unbroken surface to build up on (and is really the only reason for drilled rotors). Pads really won't make a difference other than helping with cold performance, but if they are otherwise ok in the cold a change won't do much for rain performance. You have to either keep the water off the rotors or use rotors made for the rain. Or, get in the habit of tapping the brakes every so often in the rain to keep the pads out and rotors clear.
  10. chrismorse
    Feb 16, 2004
    2,150
    chris morse
    #10 chrismorse, Oct 26, 2014
    Hi Pete,
    I have to drag the brakes for 3-4 seconds if both cold and wet. The pedal feels fine, but there is no retardation.
    Unless someone has a recommendation for a pad that is good in the rain / cold, I think I may have to try fitting the original backing plate. Not sure if that will work. Here is a shot of the stock rotor on top of the F-50 unit.
    chirs
  11. Todd308TR
    Nov 25, 2010
    11,074
    LA
    Todd
    I started doing this and they were much better but still soft in heavy rain.
  12. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,892
    Richmond
    Pete
    If you have good pedal, it does sound like a heat/compound issue unlike how Todd described his, which sounds more like water getting trapped on the rotor and pushing the pads back. I'm not sure what your pad options are for that application but there should be something more street oriented that would work better.
  13. Rifledriver
    37,089
    Lots of modern cars do not have splash shields nor do the rotors have holes or slots. In fact I think the 308 was the last Ferrari equipped with splash shields. I'll tell you what most do have though, brake ducts, the most efficient way to route a constant supply of water to your rotors and pads ever devised.
    Your problem is not water. The problem is the pads you are using.
  14. Rifledriver
    37,089
    If that is true why doesn't it happen on any of my cars or any of my clients cars or any of the other tens of thousands of Ferrari's Porsches, etc,etc,etc on the road with drilled rotors. It that was true DOT would have banned them years ago.
    I don't doubt he has a brake problem but its not rain and its not drilled rotors.
  15. fatbillybob
    Aug 10, 2002
    28,986
    socal
    Chris,
    You are totally manual now and removed all the ABS plumbing?
  16. Rifledriver
    37,089
    ABS in a 308?
  17. fatbillybob
    Aug 10, 2002
    28,986
    socal
    Thought he had a 355? So which is it?
    Opps read the set-up did not look at pics. Was on my phone
    So chris,
    Did martin calculate the master cyclinder sizing to be matched with piston caliper size for those calipers.
  18. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,892
    Richmond
    Pete
    #18 bobzdar, Oct 26, 2014
    I was saying the drilled rotors help the problem, not hurt it.
    Your clients probably never drive their cars in the rain, it's happened to me on my stock bmw. The bmw it was due to worn rotors that had a lip on the edge holding water in. It feels exactly like pad knockback. Have any of your clients experienced that or is that not real, either?
    If the pedal goes soft, it's not the pads, it's the pads getting pushed back into the caliper. If you have a firm pedal, then the pads are too cold and can't build heat quickly enough in the rain. The pad pushback is worse with floating rotors, which a lot of these big brake kits have and not a lot of stock cars have.
    If you look at the new bmw and Mercedes, they have a system that pre loads the pads in the wet to combat the issue. If it wasn't a real issue, why would they bother?
  19. kverges
    kverges F1 Rookie
    Nov 18, 2003
    3,179
    Dallas
    Keith Verges
    I have never experienced this problem and frequently race in the rain. Something else is going on as my cars have no splash shields and if anything duct work that would help bring moisture in. In fact, on the ACR-X we added water jets in the brake ducts to better cool the brakes. I've also never experienced this on the street.
  20. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,892
    Richmond
    Pete
    And I only ever experienced it in a street car, go figure. I have dealt with pad knockback before on a couple of cars and it felt exactly the same, which is why I relayed my experience - the soft pedal is the symptom that says it's not the pads. In the other situation where the pedal is firm but the brakes don't work for a few seconds definitely sounds like the pads, though.
  21. Rifledriver
    37,089
    #21 Rifledriver, Oct 26, 2014
    Nobody drives their cars in the rain???? Oh come on.
  22. fatbillybob
    Aug 10, 2002
    28,986
    socal
    As these threads develop we get more to the story. There is so much that has not been told. For example, what about bed-in procedure? How much track use? What pad compound? Oems design for a reason. Owners cherry pick what sounds like a good idea with incomplete engineering and single datapoint testing. I think Chris is lucky to find this problem in a non-urgent way. So few of us drive to the limits even on a track that testing is nearly always incomplete.
    When the brake engineers at Stoptech designed the SCCA T1 racing brake kit on my Corvette it took empirical calculation on paper, manufacture of multiple caliper set-ups, and a day of private on track testing of many sets of calipers by their test driver in my car before we had a working prototype. The process was not easy or quick and that was with professional team of 1/2 dozen guys doing it.
    I would not be surprised if there are multiple holes in your set-up where an unforseen change in operating conditions is outside your operational range.
    Pad knock back is not the whole story here. Pad knockback does happen more with full floating rotors, more with flexing calipers, less pistons in calipers, more with flexing uprights, more with flexing mounting brackets, more with poor wheel bearings, more with suspension lack of rigidity. Race calipers solve a lot of that with anti-knockback springs in the calipers. So you got new tech on a decades old design and some pad knockback could conspire just because the suspension might not be up to F50 brakes while car was designed for somewhere around 200 RWHP. But more to the story needs to be told. For example 99% of rotor hat combos sold for streetcars are not floating but actually fixed. What does chris have? Racer's use full floating typically 10-20 thous. So the more float the more "potential" knockback. You could take up the slack as many racers do before a braking point but Chris has done that with poor results. It contributes to pedal feel, modulation, and braking performance depending on knockback severity.
  23. chrismorse
    Feb 16, 2004
    2,150
    chris morse
    #23 chrismorse, Oct 27, 2014
    I recall that the ratio of master cylinder area to piston area was very close to the stock MC with the Official Brembo 308 big brake kit and was a bit concerned that I might have issues like the Brembo kit: A bit softer and lower pedal.
    After the installation, I went around the car once with the might vac and had a good firm pedal - I was stoked, then I went around a couple more times just to be sure that I cot all of the air out.
    Mertin machined custom hats to adapt the 355x32 and 330x28 rotors to the 308 hubs. They utilize Brembo bobbins and the pedal is consistently good, that is, not different hieghts, as you might expect with funky calipers, loose wheel bearings, crooked mountings or flexy mounts.
    Just for fun, I weighed the disc, hat and caliper with mounting bracket & pads and the front brake components actually weighed an ounce or two LESS than the stock iron parts. There might be just a touch more rotational inertia though.
  24. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,892
    Richmond
    Pete
    Yours sounds like a pad issue contrary to my initial post, where Todd's sounds like something else due to the soft pedal. I didn't pay attention to the weaker initial bite when cold, which will get worse when wet as it'll take longer to get heat in. If you had good initial bite in the cold then it'd be a head scratcher. What pads are available for your setup?
  25. kverges
    kverges F1 Rookie
    Nov 18, 2003
    3,179
    Dallas
    Keith Verges
    Knockback can be all kinds of issues, from warped rotors, to worn bearings, to flex in uprights over bumps (e.g. at Road America the curbs are violent enough to knock pads back). I suppose water could knock pads back, but I've never experienced that and knockback is not simply a lack of brake force; the pedal will travel farther and be softer at first or may even need to be pumped up. If you are applying a firm pedal and the car still does not slow, that is odd and I'd attribute it more to cold pads that need heat for a good friction coefficient than water, per se.
