Help... BLOWN MAF.... | FerrariChat
Discussion in '348/355' started by Marco Bussadori, Jun 20, 2008.
  1. Marco Bussadori
    Marco Bussadori Formula Junior
    Aug 6, 2007
    430
    London
    Marco Bussadori
    #1 Marco Bussadori, Jun 20, 2008
    While sorting out a mixture issue, the CO screw fell out and heard a loud pop inside of it. I took the MAF apart and found it full of muck and water and a burned out hole in the jell-o insulator with damage to the chip below.
    If you have a MAF with a broken wire, I'd be keen to buy it from you - please PM me with a reasonable price expectation.
    I can't find any reasonably priced Bosch 0280 212 018's (used in all Motronic 2.5 and 2.7 Mondial T's and 348's as Ferrari part number 136374) around and was wondering if these were interchangeable with the 355 with Motronic 2.7 Bosch 0280 213 012's (Ferrari pn. 154916)
    I found that the Bosch MAFs starting with 0280 212 018/9/22 all have the same operating volumes and flow range temperatures "HLM 2/4.7 155°" does this make them interchangeable?
    I read ND's hypertechnical post, but could not find any of the SAAB references (I'm going to try a scrap yard tomorrow).
    In the interim, Looking at the Motronic 5.2 based 355, I "crosswired" the MAF connectors, and voila' the engine runs perfectly, it would only run on one bank (the exhaust was cold on the "down" bank 5-8 for proof) otherwise. The cross wiring connects the two MAF connectors at (roll the rubber sleeve back, expose the connector pins, solder a wire across both connectors and roll the sleeve back up) the CO screw (Red/White) on Pin 6, and the signal out (orange) on Pin 5. The other pins deliver supply power, ground, hot wire burn-off and signal return.
    If you blow a MAF on the road, this can be a quick fix to get you home. Clearly in a closed loop engine with good O2's and in a well maintained engine, the airflow should be nearly identical between the banks. The fueling is predominantly done by way of O2 sensors, and the "shared" MAF signal is fine for partial throttle. While the 355 is designed with this, the F119 based cars were not. As a result this solution can only be temporary and should be returned to their standard configuration ASAP.
    Marco
  2. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,973
    MD and NE
    Robbie
    There are other non-Ferrari Bosch units that work just as well I thought for about 1/3 the price... May be a solution..
  3. Marco Bussadori
    Aug 6, 2007
    430
    London
    Marco Bussadori
    Any idea of where one can get them and potential part number translation?
  4. Llenroc
    Llenroc F1 Veteran
    5,528
    Colorado
    Vern
    #4 Llenroc, Jun 20, 2008
    The 2 parts are not interchangeable the 348 has the adjustment screw and 2.7 355 does not. there isn't even a wire(pin #6) for it in the 355 plug/cable. IIRC mid 90's V8 BMWs used the same flow meter.
  5. 285ferrari
    Sponsor
    Sep 11, 2004
    20,973
    MD and NE
    Robbie
    I have a parts number at home----I am on vacation right now--send me a PM on Tuesday and I'll look it up..
  6. Loser
    Loser Formula Junior
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    www.importecparts.com has the 355 5.2 version for $270 US (Kragen Auto Parts version is around $500 US). The 348 version is out of stock though. Maybe contact them and see if they can get you one.
  7. itsablurr
    itsablurr Formula 3
    1,016
    Carlisle, MA
    Matt
  8. m.stojanovic
    m.stojanovic F1 Rookie
    3,289
    Serbia - Niš
    Miroljub Stojanovic
    These are probably Chinese knock-offs or they could also be by a Bulgarian company called SpectroMatic. Bench tested both "brands" and, compared to Bosch, their air mass output signals are way out. In any case, if they work initially, they normally last for 2-3 months.
    SoCal1, Qavion, Pangea and 1 other person like this.
  9. Beetle
    Beetle Formula Junior
    Apr 10, 2013
    776
    We have the same problem in Oz with aftermarket MAF's they are as mentioned above but also the signals given are very very slow. You must also be aware that some aftermarket/old MAF's will give very lean mixture at higher rev ranges
