help broken bolt bumper | FerrariChat
Discussion in '206/246' started by outofpocket, Jun 25, 2011.
  1. outofpocket
    outofpocket Formula Junior
    Dec 6, 2007
    257
    Midwest
    GD
    There's a broken bolt on one of the bumpers. It snapped off at the bracket that is welded to the inside of the bumper. It appears that the bolts were welded to the bracket then the bracket welded to the bumper. What is the best way to fix this?
  2. Sunracer
    Sunracer Formula Junior
    May 18, 2005
    661
    Makati City
    Pierre Beniston
    Take it to a welding shop
  3. UroTrash
    Jan 20, 2004
    40,487
    Purgatory
    Clifford Gunboat
    Bet that will ruin the chrome.
  4. swift53
    swift53 F1 Veteran
    8,304
    E.S.
    Alberto
    100%.
  5. abstamaria
    abstamaria F1 Rookie
    Feb 11, 2006
    2,668
    Andres
    Will it be possible to cut off the broken bolt and then drill and tap a new hole so that a stud can be screwed in? Andres
  6. swift53
    swift53 F1 Veteran
    8,304
    E.S.
    Alberto
    How about a photo? I think the more info., the more solutions can be offered. Nothing like a photo...As Andy has pointed out a possible fix without damage, there may be more.
    Regards, Alberto
  7. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,321
    With maybe a Nyloc nut on the back of it & then the nut/stud stuck to the bracket with something like JB Weld as well for good measure....?
    Alternatively, If its far enough away from the chrome then the thing could possibly be drilled/tapped & then a piece of stuf/threaded rod just tack welded to the bracket without hurting the chrome.
  8. BigTex
    79,380
    Houston, Texas
    Bubba
    You cut the bolt to get the bumper removed and out of the way...
    Then examine the bracket and weld a new backing hex nut onto it.
    Are you sure it wasn't a free nut in the first place???
  9. outofpocket
    Dec 6, 2007
    257
    Midwest
    GD
    Took the bumper to the man who works on my cars and he cut a slot in the bracket, removed the broken bolt then welded a new bolt in. All the bumpers are off to be rechromed as soon as I box them.
    Thanks to all who responded.
