HELP, car won't into gear | FerrariChat
Discussion in '360/430' started by Gurjeous, Aug 3, 2013.
  1. Gurjeous
    Gurjeous Guest
    Sep 13, 2012
    103
    Hi guys, I was drivin normally down the street, been driving for about 40 min, hit a red light and next thing u know car wont go into gear, I was stuck with people and their smart remarks, if I was driving a 1989 Cherokee I'm sure they would have helped me, so choked! I got the car to the corner and tried everything from trying reverse, to shutting the car down from the bonnet to puttin in sport mode and Nuthin, doesn't go into gear, any help? Waitin for a tow truck right now
  2. Gurjeous
    Gurjeous Guest
    Sep 13, 2012
    103
    By the way it's a 01 spider 360 with A F1, new clutch about 1000 miles ago
  3. TALON30
    TALON30 Karting
    Jan 8, 2010
    171
    push the brake down "very" hard.
    than try to change the gear.
    mine did that one time
  4. TALON30
    TALON30 Karting
    Jan 8, 2010
    171
    also, if that does not work
    Do you have the tow hook that is in the front of the car (with the tool kit).
    Make sure you use it to load the car
  5. Gurjeous
    Gurjeous Guest
    Sep 13, 2012
    103
    I pushed it really hard but still no luck , so choked but thank u for the suggestion, I can hear the pump but no luck on gear changing
  6. TALON30
    TALON30 Karting
    Jan 8, 2010
    171
    one other thing I did was to roll the car about a foot. I don't know if that did it, but maybe something may have came out of alignment
  7. Gurjeous
    Gurjeous Guest
    Sep 13, 2012
    103
    I had to roll it out of traffic but still nothing, lol, thank u very much for trying to help
  8. jpk
    jpk Formula Junior
    Oct 29, 2012
    803
    Los Angeles, CA / Henderson, NV
    This issue has come up on the forums before. Usually has turned out to be a bad PIS adjustment. Might be as simple as bringing it back to the shop for that after breaking in the clutch.
  9. Stout
    Stout Formula Junior
    May 9, 2013
    259
    Helotes, TX
    Victor
    Try a power reset via the battery switch.
    Check for brake lights coming on when you press the brake pedal. If not then you may have a poor adjustment on the switch which will cause no gear change from stopped. If the car is rolling, you might be able to select a gear. I forget if the TCU will alow this after a full stop.
  10. Skidkid
    Skidkid F1 Veteran Owner Rossa Subscribed
    Aug 25, 2005
    9,539
    Campbell, CA
    John Zornes
    One more idea: If the rear deck lid is open it won't go into gear. That switch is known to be iffy. I would open the engine lid and close it again.
  11. Skidkid
    Aug 25, 2005
    9,539
    Campbell, CA
    John Zornes
    I don't know if that is the problem but if you are rolling it will allow a select, even after a full stop, but there is a minimum speed. I can't tell you what it is but it isn't very much, probably 2 or 3 MPH. I know this because I have selected N while waiting for the metering lights on the cloverleaf. I take my foot off the brake and roll, I can select a gear.
  12. Gurjeous
    Gurjeous Guest
    Sep 13, 2012
    103
    Thank u guys, the back lid is closed still no gear, I will check the brake lights when I get home, I can hear the F1 pump which is a good thing, how else can I test if its the lid or some other sensor like that?
  13. Gurjeous
    Gurjeous Guest
    Sep 13, 2012
    103
    So sad but the neighbors looked very happy lol
  14. Gurjeous
    Gurjeous Guest
    Sep 13, 2012
    103
    I checked and the brake lights r not working, so where is the adjustment have to b done or what has to b replaced? Thank u once again
  15. targa81
    targa81 Karting
    Sep 28, 2009
    116
  16. Gurjeous
    Gurjeous Guest
    Sep 13, 2012
    103
    I'm havin a really bad night, I went to check and looks like the switch is bad but next thing u know the tranny light comes on and now I can't hear the F1 pump, all I touched was the switch. A code of P1569 came up but even when I erased it the tranny light come back on, I main power switched it off for the night. Gould the F1 pump stopped workin cause of that brake switch?
  17. vrsurgeon
    vrsurgeon F1 World Champ Silver Subscribed
    Dec 13, 2009
    16,543
    Charleston, SC
    Curt
    Gotta get it onto an SD2 or Leonardo and get it scanned.
  18. WJGESQ
    WJGESQ Formula 3
    Dec 30, 2004
    1,477
    These flappy paddles can be fun---but these stories are scary as hell.
  19. Stout
    May 9, 2013
    259
    Helotes, TX
    Victor
    I don't know if the switch is special or if there is resistance when open which could cause the TCU to know if it was disconnected. If the switch is two wire, you could short them together to see if the brake lights come on. Then see if it will go into gear.
    Don't know about the code. I hate troubleshooting multiple problems but maybe they are related.
  20. Skidkid
    Aug 25, 2005
    9,539
    Campbell, CA
    John Zornes
    And THIS is why power cycle reset is a bad idea. When you did that you cleared all stored codes so they have very little information to go on when diagnosing the problem. Power cycle reset is WAY over used even though it is one of the first things people suggest. It can cause you a world of problems and more expense down the line.
  21. Gurjeous
    Gurjeous Guest
    Sep 13, 2012
    103
    I'm going to change the switch, can u buy it at Lordco or do u have to buy it online, I really would like to get it today so I can get my car into gear and into my garage, don't like it parked outside.
  22. big_guy
    big_guy F1 Rookie
    Sep 9, 2007
    3,190
    Ontario, Canada
    Excellent tip. Thanks!
  23. Stout
    May 9, 2013
    259
    Helotes, TX
    Victor
    A power cycle will not clear OBD2 codes. They must be cleared by the reader. It will reset the dash lamps by removing power. OBD1 codes are cleared by a power off. Not sure about codes only readable by the SD2 and SD3 but I doubt they are cleared without the tool? He already pulled the OBD2 codes available via a reader.
    When you have nothing else that seems to work, what else do average owner have to try. I'm pretty handy and am not going to tow my car to the dealer before I have exhausted all of my options. If it does clear a code and get the car back on the road, your are back on the road and make arrangements for service at your convenience instead of immediately.
  24. vrsurgeon
    Dec 13, 2009
    16,543
    Charleston, SC
    Curt
    The problem is.. the F1 system has so much that is below the radar that is designed to be serviced with the Sd2. It's not friendly to DIY diagnosis beyond what has been done. You can trace the wiring schematic, perhaps there's a crossed path for current and a short. Many of the circuits appear to be shared. Maybe it's the brake switch... I presume fuse is OK. With a CEL it's imparting the system is connoting a fault. Knowing what it sees and is preventing it for shifting from you is a very very good start.
    I agree do all you can before you bring it in... but it's not as friendly as my 3 pedal.
    And I vowed I would let that slip in... ;)
  25. rustybits
    rustybits F1 Rookie Professional Ferrari Technician
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    If the brake lights are not working, nor will your gears. It's either a fuse (likely) or the switch on the brake pedal. Checking with an Sd2 will not show a fault in this case, as the gearbox control unit simply thinks you haven't put your foot on the brake.
