458 - Help! Changing battery | FerrariChat
458 Help! Changing battery
Discussion in '458 Italia/488/F8' started by tsmithmdtx, May 31, 2019.
  1. tsmithmdtx
    tsmithmdtx Rookie
    Apr 17, 2011
    33
    Tyler, Texas
    Have everything done except the positive terminal/fuse box. Does the fuse box just lift up once the positive terminal is disconnected? Does the fuse box cover have to be removed?
  2. RayJohns
    RayJohns F1 Veteran
    7,926
    West Coast
    Ray
    If you undo the 10mm bolt clamping the band to the + terminal and it won't lift off, then you'll have to pop the cover off the fuse block thing and you'll see two small phillips head screws; those thread into some small red expansion push-plugs that secures everything to the battery. Unscrew those and then everything should come free.
    Ray
  3. up4speed
    up4speed F1 Rookie
    3,693
    Long Island, NY
    Chris
    Yes, what Ray said
  4. tsmithmdtx
    tsmithmdtx Rookie
    Apr 17, 2011
    33
    Tyler, Texas
    Thanks for your help. Got it changed out and everything working well.
