Help Clutch bolt removal tool needed to borrow. | FerrariChat
Discussion in '348/355' started by speedracer1610, Apr 12, 2007.
  1. speedracer1610
    speedracer1610 Formula Junior
    Aug 25, 2006
    332
    nor cal
    Craig D
    Does anyone in the San Francisco bay area have this tool I can borrow or can I bring the the unit over to you thanks. PM me please.
  2. PAP 348
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    #2 PAP 348, Apr 13, 2007
  3. speedracer1610
    Aug 25, 2006
    332
    nor cal
    Craig D
    pap, i don't have a welder.
  4. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Not bad PAP..with skills like that you are employable...don't give up you'll get a job sooner or later...lol
  5. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    It just means PAP's painting skills are subpar :eek: ;) ;)!
  6. PAP 348
    Dec 10, 2005
    100,224
    Pap
    WHAT!!! Pap work! Nooooooooooooooooooo chance! :p:p:p
  7. PAP 348
    Dec 10, 2005
    100,224
    Pap
    That may be a problem. :p:p:p
    You can actually buy the tool to do the job. :)
    Unless you dont want to spend the money, for a one off job like this? :)
  8. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    #8 jm3, Apr 13, 2007
    Go buy the spindle nut wrench for the early Dana 44 (4WD front solid axle) . It will be in stock in many stores. Bring your clutch assembly down, and test fit them on the nut. Its not perfect, but it will do the job and it won't ruin the nut.
    JM3
  9. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    JM3, that looks like a 6-pin socket, and it doesn't look remotely strong enough to deal with the torque on the clutch ring nut. Have you had success with that? I made a tool out of one of these 4WD sockets, even beefed it up, and it BARELY worked once, then chewed the pins right off it. So I purchased the Hill tool.
  10. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    #10 jm3, Apr 13, 2007
    I have one I used three times. Here is an actual pic, I bought it at Kragen, and the teeth are actually recessed. There is "support" around the teeth, so they couldn't move anywhere. Its not perfect, but it works.
    POWERBUILT
    4 LUG X 2-1/2" INNER
    SPINDLE NUT
    CHROME VANADIUM
    648477
    JM3
  11. lusso64
    lusso64 Formula 3
    Apr 12, 2004
    1,535
    Simi Valley
    David
    #11 lusso64, Apr 13, 2007
  12. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    That's more like it, jm3! That looks like a proper impact socket. But the ring nut on the 348 clutch is probably torqued MUCH tighter than the spindle nut on the Dana 44 (I don't know this for certain) so that tool may not be designed for the load on the Ferrari. Is it 1/2" drive?
    If it works, great!
  13. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    Of course.
    I would consider this tool an emergency tool that works very well. Kinda like using a screwdriver for a prybar.
