HELP! DEAD 355 | FerrariChat
HELP! DEAD 355
Discussion in 'Technical Q&A' started by ametelsky, Jun 1, 2007.
  1. ametelsky
    ametelsky Rookie
    May 13, 2007
    25
    Rochester, NY
    Help!
    I am a brand new owner of a 98 355 spyder. Started fine, warmed for a minute or two. shut down to answer the phone. Now when I turn the key I get NOTHING, no dash warning lights, no starter. lights and radio etc work.
    Any ideas?
    Thanks,
    Alan
  2. J. Salmon
    J. Salmon F1 Rookie Owner Rossa Subscribed
    Aug 27, 2005
    4,367
    VA
    Did you push the alarm button? You need the 2 chirps or nothing will happen.
  3. sparta49
    sparta49 F1 Veteran Owner
    Mar 3, 2001
    7,804
    LA
    Frank
    Bury it and get a 348. Sorry. I couldn't resist. :) :)
  4. ametelsky
    ametelsky Rookie
    May 13, 2007
    25
    Rochester, NY
    OK,
    Bear with me, I have no specific alarm manual. I have the red fob only. I have had times where I forgot to push it, and you get dash warning lights but nothing else - push it, get the chirps, and no problem. I am getting the two chirps, but still nothing.
    Something new though. Now when I arm it, I get one chirp, then three slow chirps after that...
  5. ametelsky
    ametelsky Rookie
    May 13, 2007
    25
    Rochester, NY
    OOPS,
    Bonnet was open, that was the three chirps.
    Still Dead as can be, Ecu fuse is good...
  6. bwassam
    bwassam Formula Junior
    Jan 3, 2005
    635
    North Bend, Oregon
    Robert Wassam
    I'm thinking that you need to take a look at your battery. Perhaps your ignition switch needs work. It would be best to just start tracing down the circuit and see what it is. Sooner or later you'll find one or more parts that need replacement.
    Congratulations on getting a nice car. Good luck with it.
    Bob Wassam
  7. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    I had (almost) same problem as a brand new owner...since when do you have to disarm a car to start it when I didn't arm it in the first place? I'd guess battery is fine for now, it doesn't take much juice to at least try to crank over. If you're getting nothing at all may be an arm / disarm issue. On my black fob I hit the button once and two flashes means it's disarmed.
  8. ametelsky
    ametelsky Rookie
    May 13, 2007
    25
    Rochester, NY
    Thanks everyone. As a condition of sale, the previous owner had the steering column housing refinished (Sticky Problem). When they did the work, they must have jarred the harness connector on the ignition switch. I took apart the column, replugged the connections, and all is well again.
    I do appreciate the responses!
    Alan
  9. UConn Husky
    Nov 11, 2006
    4,425
    CT
    Jay
    Good to hear...now go enjoy that beauty! I did the same to my steering column recently, lucking I avoided touching any connectors... :)
  10. tbakowsky
    tbakowsky Two Time F1 World Champ Consultant Professional Ferrari Technician
    Sep 18, 2002
    20,011
    The Cold North
    Tom
    You think you got issues?? How about a 355 when you pull the key out the engine is still running!!
  11. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Ha! You'd know much better than me, but I'd pull off the harness connector to the ignition switch...if the 355 was *still* running, then I'd pull the relays, one at a time, to the ecus.
    (of course, if it is still running after that, call her "Christine" and get the heck out of there!)
  12. UConn Husky
    Nov 11, 2006
    4,425
    CT
    Jay
    That's actually an upgrade feature :) My '69 Firebird does that, very handy to hop out and unlock the garage door without having to turn the car off.
