Help, F360 engine trouble | FerrariChat
Discussion in 'Technical Q&A' started by mingjenpan, Mar 31, 2008.
  1. mingjenpan
    mingjenpan Rookie
    May 26, 2007
    14
    Taiwan
    Dear all, I'm experiencing engine trouble with my F360, when I reved it up to 6000 rpm, it will stall and slow down. I turned it off and on, it happened again. Everything is OK under 6000 rpm. When it's connected to a SD3, the SD3 showed few errors
    * THROTTLE POSITION SENSOR PLAUSIBILITY
    * THROTTLE POSITION SIGN (B2) Hi
    * THROTTLE SAFETY FUNCTION (B2) RANGE
    * THROTTLE SAFETY FUNCTION (B1) RANGE
    I'd replaced an accelerator potentiometer and both throttle bodies took from another F360, it still happened. Please suggest my next action before I go to the dealer.
