HELP... F430 Mirror Wiring or Wire Diagram? | FerrariChat
Discussion in 'Technical Q&A' started by Rippin6Gears, May 30, 2017.
  1. Rippin6Gears
    Rippin6Gears Rookie
    Oct 23, 2016
    22
    Seattle
    M
    Well in need of some help for replacement f430 wiring to a new plug and mirror.
    Have a total of 7 wires total.... 2 grey, black, yellow/black, orange/black, yellow and blue.
    Anyone maybe have a wiring diagram or pin out for me? Searched with no luck anywhere. Thanks!
  2. leoparker990
    leoparker990 Karting
    Apr 28, 2017
    54
    United Arab Emirates
    Leo Parker
    #2 leoparker990, Jun 2, 2017
  3. Qavion
    Qavion F1 World Champ
    14,277
    Ian Riddell
    #3 Qavion, Jun 4, 2017
    Do you have to replace both male and female plugs? If the car side of the plug is intact, are the colours visible or is it a sealed harness?
    Often, the (mirror) internal colours are not shown on diagrams.
    The 360 has seven pins on the plugs also. According to the 360 Workshop Manual, the 360 left mirror (on the car side of the harness) has the same colours and pin configuration as the 360's right mirror. It's possible that the 430 is similar. The driver's mirror on the F355 also has 7 pins.
    The two grey wires in the separate harness(on the mirror side) will be the outside temperature sensor (because they are not present on the passenger side).
    Two wires will be for the mirror heater (one of these will be the black earth wire).
    The remaining are for mirror motor control. One wire will be common to both motors.
    You may have to find the wires by trial and error.
    (EDIT: I orginally thought the centre pin was a different colour on the 360. I rechecked and they are the same (according to the WSM))
    Cheers.
