HELP !!! FERRARI 348 HIGH IDLE | FerrariChat
Discussion in '348/355' started by tommygunct, Mar 19, 2013.
  1. tommygunct
    tommygunct Karting
    Dec 26, 2012
    175
    Stuart florida
    #1 tommygunct, Mar 19, 2013
    HELLO PEOPLE CAN ANYONE PLEASE HELP ME I HAVE AN IDLE PROBLEM WITH MY 89 348TB I CANT GET IT TO KEEP A LOW IDLE I HAVE HIGH FLOW CATS AND CUSTOM EXHAUST
    I JUST CHANGED THE O2 SENS. NEW K&N AIR FILTER MY AIR SENSORS ARE RIGHT AT 383 LIKE THE BOOK SAYS I TOOK OFF THE THROTTLE BODS AND CLEANED THEM AND THE AIR FUEL ADJ SCREWS AND SET THEM TO 1 1/2 TURNS OUT CHECKED THE VAC. LINES THEY LOOK GOOD AND HAVE NEW PLUGS AND THE WIRES LOOKED GOOD OLD PLUGS WERE PERFICT LIGHT TAN COLOR ALL OIL AND COOLENT TEMPS ARE WHERE THEY SHOULD BE OIL PRESS. IS GREAT I TOOK OUT THE SCREENS ON THE AIR FLOW SENS. AND TRIED TO ADJ THE IDLE EVERY WAY POSSIBLE BUT ITS AT 1300 -1500 IT RISES AND FALLS APROX 100 RPM AT TIMES I WAS TOLD IT HAD A BELT SERV APROX 4 YEARS AGO IT REALLY DOES RUN MINT AND SHIFTS MINT BUT FOR THE LIFE OF ME I CANT GET THE IDLE TO 1000 RPM WHEN I GOT THE CAR THE AIR FUEL ADJ SCREWS WER OUT 2 3/4 ON THE PASS SIDE AND THE AIR SENS. WAS SET TO 940 ON THE DRIVERS SIDE THE AIR FUEL ADJ WAS OUT 2 1/2 TURNS AND THE AIR FLOW WAS AT 550 ANY IDEAS OR FIX ANYONE CAN HELP ME OUT WITH I KNOW ITS BELT SERV TIME BUT ITS JUST RUNNING SO GOOD RIGHT NOW I HATE TO TIE IT UP JUST YET BUT I WILL SOON CHANGED THE LUBES OH AND ONE MORE THING MY CLUTCH GRABS HIGH IS THAT NORMAL ?? I DONT SEE OR FEEL ANY SLIPPING AND THE CAR HAS GREAT POWER AND TOURQUE WHERE DO THE CLUTCHES NORMLY GRAB HIGH OR LOW ?? THANKS GUYS TOMMY GUN
  2. zakeen
    zakeen Formula Junior
    Aug 29, 2004
    989
    Czech Republic
    And in lower case:
    hello people can anyone please help me i have an idle problem with my 89 348tb i cant get it to keep a low idle i have high flow cats and custom exhaust
    i just changed the o2 sens. new k&n air filter my air sensors are right at 383 like the book says i took off the throttle bods and cleaned them and the air fuel adj screws and set them to 1 1/2 turns out checked the vac. lines they look good and have new plugs and the wires looked good old plugs were perfict light tan color all oil and coolent temps are where they should be oil press. is great i took out the screens on the air flow sens. and tried to adj the idle every way possible but its at 1300 -1500 it rises and falls aprox 100 rpm at times i was told it had a belt serv aprox 4 years ago it really does run mint and shifts mint but for the life of me i cant get the idle to 1000 rpm when i got the car the air fuel adj screws wer out 2 3/4 on the pass side and the air sens. was set to 940 on the drivers side the air fuel adj was out 2 1/2 turns and the air flow was at 550 any ideas or fix anyone can help me out with i know its belt serv time but its just running so good right now i hate to tie it up just yet but i will soon changed the lubes oh and one more thing my clutch grabs high is that normal ?? i dont see or feel any slipping and the car has great power and tourque where do the clutches normly grab high or low ?? thanks guys tommy gun
  3. tommygunct
    tommygunct Karting
    Dec 26, 2012
    175
    Stuart florida
    hey zakeen im sorry i didnt know i was turning in an english test at school i have a broblem with my ferrari not with test paper writing but thank you for the input
    NOW BACK TO THE PROBLEM AT HAND GOT ANY INPUT ON THE FIX ????
  4. Nosevi
    Nosevi Formula 3
    Jul 8, 2011
    1,990
    Lincoln
    Pete
    Hi there. Have you cleaned out the Idle Control Valves? Located forward of the MAFs. I was having idle problems, hit 4000 rpm once on idle. Cleaned out the ICVs with MAF cleaner and it sorted it.
  5. Nosevi
    Nosevi Formula 3
    Jul 8, 2011
    1,990
    Lincoln
    Pete
    #5 Nosevi, Mar 19, 2013
    You look like you know what you're doing but just in case, it's part number 13 on this diagram.
    Edit: turns out I didn't know what I was doing. Is attached now (hopefully)
  6. tommygunct
    tommygunct Karting
    Dec 26, 2012
    175
    Stuart florida
    thank you so much i will try it and let you know so much air this and valve that and sensor stuff on these i gotta get used to these things but i know one thing i get in my baby and take a drive and i dont care about a dammed thing thats going on in the world and any and all problems with it i may come across is well worth the trouble
    god bless ya enzo i should have bought one when i was 21 but i will from now on never be without one
  7. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    40,171
    Huntsville, AL., USA
    Andrew
    Wow, a Giallo TB... stunning. :D
    Hope you get the idle sorted soon. :)
    All the best,
    Andrew.
    PS:
    Also, your wheels are on backwards.
    :eek:
  8. tommygunct
    tommygunct Karting
    Dec 26, 2012
    175
    Stuart florida
    #8 tommygunct, Mar 19, 2013
  9. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    I wouldn't be surprised if your left and right throttle butterflies are way out of synch, especially if someone has been messing with the balancing screw on the linkage, in a misguided attempt to adjust the idle speed that way. If you have a shop manual, look at figure 55 on page C87. In general terms, the linkage for each butterfly should be against its stop screw (#2) when the throttle is at idle. Once screw #4 is set so that the butterflies are in synch, it shouldn't ever need to be adjusted again.
    Good luck getting it right ASAP!
  10. tommygunct
    tommygunct Karting
    Dec 26, 2012
    175
    Stuart florida
    MILTONIAN thank you the butterflys were out of sinc purrs at 1100 now
    god i love my car man an enzo got nothin on my 348 i know i know ...........
    im just telling myself that god please bring me an enzo i swear i will never speed ever !!
  11. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,171
    Andrew
    Excellent. Happy motoring Tommy. :D
    All the best,
    Andrew.
  12. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    You fixed it yourself / for free / with just a screwdriver? That's what I like to hear!
    If the throttles are set up even close to correctly, the Motronics should take care of the idle speed. There isn't an actual "idle speed screw" anywhere on the linkage.
    Good thing you changed those wheels, or someone would have complained that your stock wheels were mounted on the wrong sides of the car...
  13. Nosevi
    Nosevi Formula 3
    Jul 8, 2011
    1,990
    Lincoln
    Pete
    At least two of us already did, but only one had the 'class' to do it via PM :D
    Just teasing, Andrew :)
  14. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,171
    Andrew
    Well, I've always presented myself as enthusiastic rather than classy. ;) :D
    All the best,
    Andrew.
  15. Nosevi
    Nosevi Formula 3
    Jul 8, 2011
    1,990
    Lincoln
    Pete
    Lol.
    And I've never been accused of being subtle. :)
  16. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,171
    Andrew
    Is that a subtle way of declaring that you're, on occasion, indelicately mirthful? :)
    Vivaciously,
    Andrew.
  17. Nosevi
    Nosevi Formula 3
    Jul 8, 2011
    1,990
    Lincoln
    Pete
    You're starting to use long words now, which is just unfair! But yes, can't help it sometimes :)
  18. Harry348
    Harry348 Karting
    Nov 20, 2012
    64
    Middle of France
    Harry V
    Someone stole your fuel cap
