Help, Gas leaking from TR | FerrariChat
Discussion in 'Boxers/TR/M' started by 1TRICK6, Aug 19, 2015.
  1. 1TRICK6
    1TRICK6 Karting
    Aug 28, 2014
    159
    So. Cal (L.A./O.C.)
    Jim
    1st time I filled up my 89TR (owned for almost 2months) got home and parked it on my slightly inclined driveway. Smelled gas and looked underneath and saw a steady drip of gas from the middle of the car (just to the left of the oil filter and right at the edge of the cover plates). By the time I parked it into the garage to jack it up it stopped leaking and I couldn't find where it was leaking from. Took it for another drive and parked it in driveway, it starts leaking again, but as soon as I drive it into the garage which is level it stops leaking. Where could it be leaking from? Could I have overfilled the gas? Just had my 30k service 3wks ago too.
  2. Steve Magnusson
    26,799
    There are several hoses connected to the top edge of the gas tank that would not normally be wetted (fuel evaporation system, venting to the gas filler neck, etc.), but if they are cracked and you have a full tank on an incline = liquid fuel could leak out; whereas, it wouldn't when on a level surface. See TAV 9 and 10 in the TR SPC.
  3. ozziindaus
    ozziindaus F1 Veteran
    Aug 16, 2012
    9,799
    Detroit
    Sam
    #3 ozziindaus, Aug 19, 2015
  4. 88Testarossa
    88Testarossa Formula 3
    Sep 25, 2012
    2,450
    Annapolis and Daytona Beach
    Al
    Same thing happened to me five years ago. Replaced the fuel lines. Do not drive it until you fix the problem. Good luck. And, never overfill ANY car.
    Sent via itty bitty electrons
  5. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,530
    romano schwabel
    to be on a safe way I would replace all fuel hoses ( so included the connection between the 2 tanks and the return lines ) ASAP
  6. N17RO
    N17RO Formula Junior
    Apr 9, 2013
    260
    UAE
    Craig
    It still maybe leaking when on a flat surface but only when its on the incline physically tracking to where it can run out. Remove the protection plates and have a physical check. They are not difficult to remove.
    I had a leak that looked the exact same as Sam has shown above and it was the hoses connecting to the drainage section. It sits right next to the pumps. All mine needed was to be properly tightened.
    Once you have access to the area youll be able to trace the leak. When youre in there if your fuel lines look old and/or perished then replace them even if they are not the root cause of the leak.
  7. peteficarra
    peteficarra Karting
    Jun 22, 2010
    158
    ontario
    peter j ficarra
    Do not pull on the fuel lines to remove them. You must cut them with a razor blade at the fitting FIRST. The nipples are aluminum and will break right off. Change all of them and save your self a lot of headaches.
    People with Italian cars should keep a bag of marshmallows handy at all times because of the old gas lines and the wiring.
  8. 1TRICK6
    1TRICK6 Karting
    Aug 28, 2014
    159
    So. Cal (L.A./O.C.)
    Jim
    Thanks all for the good advice.
