Help gearbox locked up | FerrariChat
Discussion in '348/355' started by MaterMech, Aug 16, 2007.
  1. MaterMech
    MaterMech Formula Junior
    Feb 26, 2007
    476
    Los Gatos CA
    Mark Johnson
    Ok I think I f-upped the gearbox. After a burnout the car will not move in gear and the engine dies when the clutch is released in gear or in neutral. Any ideas? I am antcipating gearbox rebuild. Anybody seen this before? Damn cars only been on the road since last Thursday :(
    Mark
  2. Juan-Manuel Fantango
    Juan-Manuel Fantango F1 World Champ
    14,658
    Juan
    You need fatbillybob-fast! I noted you are in CA, and he can help you. This is for all those guys in that last thread about burn outs.
  3. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Absolutely!!! FBB and Ernie are the best, maybe even Bruce and Oz could show up to keep the beer and food flowing.
  4. MaterMech
    Feb 26, 2007
    476
    Los Gatos CA
    Mark Johnson
    Clutch is off and is there are no problems there. Drained gearbox oil and I've got glitter but it's hard for me to believe that one burner did that. Must have been a pre-existing problem. A little bit of scrap on the plug magnet. No nasty crunching sounds during the burnout so I'm hoping it's the lay shaft bearing. Is there a cover I can take off to get a better look. Either way this thing is coming apart. I guess I did too good of a job on the motor :) So much for taking this car to Vegas this weekend.
  5. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    #5 PAP 348, Aug 17, 2007
  6. Ricambi America
    Sponsor Owner
    #6 Ricambi America, Aug 17, 2007
  7. MaterMech
    Feb 26, 2007
    476
    Los Gatos CA
    Mark Johnson
    Yup she rolls in Neutral so that would mean that the differential and the main shaft are turning. The counter shaft has to be locked and the gears are in question. Cross your fingers.
  8. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Before tearing the transmission apart, I think I would disconnect the shifter cables and make sure that the 'box is actually in neutral. It MAY be possible that one of the cables has stretched, or popped off the linkage levers, or something like that, and the box is stuck partway in gear. I think I remember a thread a long, long time ago where someone had a nut back off from one of the cable attachment points and caused problems. Were you "speed shifting" while doing the burnout?
  9. ForzaMaranello
    ForzaMaranello Karting
    Jul 15, 2006
    234
    Louisville CO.
    Robert T
    Burnout? I thought that's what the Corvette's were good for?
  10. plugzit
    plugzit F1 Veteran
    7,782
    Redondo Beach, CA
    Bruce Bogart
    Like he said. No big parts in it, probably just "between gears"
  11. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    +1 I have seen other gear boxes do similar things (not mine ;)). Sometimes the gear selector either braeks or gets locked in when one of the shifter shafts slides into gear and the selector did not go with it. Then the selector cannot access the slot in the shaft to bring it out of gear.
    You may need another person to move the shifter while you watch the linkage move. At least you can find out if the problem is on the 'outside'.
    How does the shifter feel? Does it go freely into all the gates?
  12. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Wasn't there a Mondial owner who had something similar happen to his car that just turned out to be a gear selection "fork" that popped out of the correct alignment?
    I was thinking that he did something with the gearshift and the tranny popped the fork back into the correct position on its own. Complete auto-cockpit fix!
    Might not be the same thing, but here's the thread with his fix: http://www.ferrarichat.com/forum/showthread.php?p=136858112#post136858112
  13. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Yeah..... I bet its something like that...... :eek:
  14. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Oh man, are you messing with me on a Friday?!
  15. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Dude,..... I was NOT sarcastic !!! What you said, sounds very likely :)!!
    BTW, I forgot its friday!!!!! :D
  16. MaterMech
    Feb 26, 2007
    476
    Los Gatos CA
    Mark Johnson
    Shift linkage is correct and tight. It moves through all gears normally. Clutch shaft is completely locked I cant even wiggle it. I'm wishing I was in town this weekend to start adressing the issue.
  17. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Hang on "a tick" here, juuuuuust in case.
    Are you saying that the smaller diameter shaft with the finer splines won't move (this is attached to the engine, and shouldn't move unless the engine is turning) or are you saying that the larger diameter shaft with the coarser splines (attached to the clutch) won't move? That shaft SHOULD rotate when the gearbox is in neutral. The smaller shaft runs through the middle of the larger shaft, of course.
    Still hoping that your tranny is OK.
  18. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Uh oh?
    If I'm understanding this correct, to me it sounds like you have something wedged between the ring and pinion gear (aka bevel gear). If so, your box will have to come apart. Get the car in the air and remove the inspection plate on the bottom. You will then be able to see up inside the gear box. Pull the cover and let us know what you find.
    I hope that damn oil pump bearing hasn't struck again.
  19. MaterMech
    Feb 26, 2007
    476
    Los Gatos CA
    Mark Johnson
    #19 MaterMech, Aug 17, 2007
    Found it! I just don't know what to do about it yet. The clutch shaft (larger splines) lossened up and seized to the back of the throw out bearing housing. It moves in and out of the tranny about 3/8 of an inch. I was hesitant to pull on it but I'm hoping the assembly can be removed from the back of trans. Radially there is about ten degrees of play. I threw in some pics of the car too. Bevel gears and trans internals look to be in great shape ie. gear wear patterns no debris, crisp angles on syncros. Once the throw out bearring housing came off everything freed up.
  20. lusso64
    lusso64 Formula 3
    Apr 12, 2004
    1,535
    Simi Valley
    David
    With that sort of "injury" I'd be concerned about the gear on the other end of that shaft and the one it interfaces with.
    When you replace the bearing flange and the bearing, ensure you upgrade to the Hill Engineering items - similar price to OEM but vastly superior. They tend not to self destruct too.
    Keep us all posted, preferably with pics.... I just hope it's not too ugly on the other side.
    Very nice car BTW. Love the 360 wheels...
  21. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Shweeooo
    Let's just hope, it only the bearing.
  22. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    If you had to have a bearing lock up, the throwout/slave would be a whole lot better than most any other!
    At least it's external to the tranny box.
  23. ForzaMaranello
    Jul 15, 2006
    234
    Louisville CO.
    Robert T
    I too like the 360 wheels! NICE!
  24. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    #24 Miltonian, Aug 18, 2007
    So perhaps ring nut #14 backed off on the end of clutch shaft #2, allowing gear #1 to go out of alignment on the shaft and lock up against the corresponding gear inside the box? Then once cover #19 was removed it allowed gear #1 to "unlock" and rotate?
  25. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    If #32 seizes internally, would item 2 be able to turn?
