HELP ... hex nut stripped..... | FerrariChat
Discussion in '206/246' started by ajmarton, Oct 28, 2006.
  1. ajmarton
    ajmarton Formula Junior
    May 3, 2004
    305
    Los Angeles
    Ok. This board has been great with fixes and I need a good one for this situation! I am working on a Porsche 928 and several hours into a dash removal when I came across a hex nut in a very tight spot. Unfortuately, someone had been here before and stripped the nut! I tried carefully to get the nut to move but no luck. Tried some WD40 and left it there for an hour still no luck and I really cannot torque it enough. Any suggestions on how to work around this? I am so close to removing the damn dash!
  2. Steve Magnusson
    26,819
    Do you mean that the nut's outer drive hex shape is rounded off or that the threads themselves are damaged?
  3. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    If you have the room, you may be able to slot the head with a dremel and get it out with a flat head screw driver. Otherwise, you may have to drill it out. What a PITA. Been there, so I feel your pain. Good luck!
  4. rwk360
    rwk360 Formula Junior
    Aug 26, 2005
    394
    Pebble Beach, CA
    R W Kenton
    Before you resort to destructive or other acrobatic methods, try a product called PB Blaster (avail at NAPA, etc)- much better penetrant/break loose agent than WD40. Good Luck.
  5. ajmarton
    May 3, 2004
    305
    Los Angeles
    It's the hex part - the outer shape is round with a hex in the center - if that makes sense. I will try some better penetrating oil and epoxying in the hex socket to see if I can get it to budge.
  6. PWehmer
    PWehmer Formula 3
    Oct 15, 2002
    1,733
    Surrounded by Water
    Sounds like a socket head screw.
    I have had good luck getting these out with a tool from
    www.mcmaster.com
    Look in their catalog on page 2710 at the "socket screw extraction sets"
    You'll want part #2643A56
    Or you can drill the head off which will leave you a stud nub that you can grab with vise grips.
  7. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    I like 928s been looking at one recently.
    It's not a nut, its a bolt, right?
    If its a nut, try a splitter. If a bolt and depending how much wiggle room you have, try vice grips secured very tightly and tap the head of the bolt, If room allows. I have tried slotting and filing flats on the side, both methods failed, any success has been with vice grips. If it does not move, spray again and leave it for a while. Try too hard and something else might break.
  8. jimangle
    jimangle F1 Rookie
    Nov 5, 2003
    2,506
    Haverford
    James
    It sounds like an allen head screw you're talking about right? The outer shape is round? The inside allen head portion is rounded out? Just get a really small pair of vice grips and clamp it around the outside of the screw. You should be able to break it loose that way if I'm right about the fastener.
  9. brokenarrow
    brokenarrow F1 Rookie
    Sep 25, 2006
    3,737
    Txass
    Bill
    That's and allen wrench screw. Try channel locks on it. If that doesn't work, drill it out and run new threads. Homedepot sells a die kit for $25 that you can use for all these stubborn screws. It takes fifteen minutes to drill it out and run threads. Eaaaaasy!
  10. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    It sounds like an allen head bolt, not a nut - correct?
