help, how does this come apart? | Page 3 | FerrariChat
Discussion in 'Technical Q&A' started by Sledge4.2, Sep 20, 2014.
  1. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,789
    Marin
    Geno
    #51 Sledge4.2, Nov 3, 2014
    There is no room to tap a pipe or sleeve, cant even fit a hammer in there.
    so, I am making a collar/pipe to ride on the bearing face, and then a slotted bar, using the existing holes in the differential case to press the collar/pipe onto the bearing and push it (gently) into place.
    when done I am planning on selling this device for a fortune on ebay.
  2. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    Very slick.......but before you go to all that trouble, have you tried simply tapping around side-to-side with a slender punch / nail set ?
  3. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,789
    Marin
    Geno
    Yes, i did. You can barely get any force on it due to the space limitation, and i didnt want to f anything up.
    I do have a sinking fear that pulling the carrier off with the jack screws wasted the bearing.....
    here is a dumb question: when I turn the axle from the other side of differential, the bearing in question doesnt rotate/spin, but the inside shaft does....hard to explain, maybe i will post a youtube video, but somehow I though the bearing should rotate..
  4. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,789
    Marin
    Geno
    #54 Sledge4.2, Nov 3, 2014
    when you turn the differential from the other side, the only part that moves is marked with the red arrow. It rotates around, while the bearing doesnt move at all....
  5. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,789
    Marin
    Geno
    #55 Sledge4.2, Nov 6, 2014
  6. finnerty
    May 18, 2004
    10,406
    Nice work --- happy motoring :)
  7. phrogs
    phrogs F1 Veteran
    7,375
    Kzoo Michigan
    I hope you do because ebay is waiting to make their 10% final value fee off of you!
  8. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,789
    Marin
    Geno
    With all the jalpa owners out there looking to do this task with the engine in the car, I will probably patent it
