help I am changing the wires | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by rickyx, Jun 29, 2006.
  1. mike
    mike Formula Junior
    Nov 2, 2003
    721
    Colorado
  2. f355spider
    f355spider F1 World Champ
    18,061
    Yes, get NEW covers for the plug holes...you are obviously getting water down them when driving in the rain or washing the car. New covers will seal tightly, and keep the water out. I had this problem on my 78 308GTS and after replacing the plug covers, no more problems with water getting in! You will get a BAD miss from this common problem.
  3. mike
    mike Formula Junior
    Nov 2, 2003
    721
    Colorado
    QUOTE=ham308]The connectors on my 308 have around 2 kOhm resistance (so there is something other than pure metal in there) and the cables are approx. 1 kOhm more.
    I don't use the resistance sparkplugs and till now, I have had no problems with misfires, corrosion and so on. Oh, and no interference on the radio, when it decides to work.[/QUOTE]
    From reading the post and the above captioned quote, it appears that if properly set the wires should ohm out at about 1 kOHM..
  4. rickyx
    rickyx Karting
    May 9, 2006
    117
    How do you take of the rotors?
  5. matteo
    matteo F1 World Champ
    Aug 1, 2002
    13,748
    On a plane somewhere
    Heir Butt
    Pull them off the cam shaft
  6. rickyx
    rickyx Karting
    May 9, 2006
    117
    I am a bit confused about the plugs and the wires
    The NGK plugs are of the resistor type and the wires as well?
    Reading so many opinions, my question is can they be combined or not?
  7. mike
    mike Formula Junior
    Nov 2, 2003
    721
    Colorado
    Yes you can use the resistor plugs. But the resistance I'm referring to specifically is the resistance you may have if the plug wires core is not pierced correctly in the distrubutor cap. (if not pierced correctly you will have too much resistance). The wires themselves will have some resistance ...yes! The issue is keeping that value low (hence the correct piercing of the plug wires)..
    Come on someone here has to know the ohm value for the plug wires from the cap to the extensions..throw me a bone here, so we can help ricky x.
  8. wolftalk
    wolftalk Formula Junior
    Jan 27, 2004
    367
    san franciso area
    phil
    the taylor 8mm spiral wire is about 350 ohms/ft
