Help, I need a GTB rear quarter window gasket | FerrariChat
Discussion in '308/328' started by ztarum, Apr 21, 2010.
  1. ztarum
    ztarum Formula 3
    Mar 30, 2008
    1,302
    South Jersey, USA
    I'm looking for part number 60058302. Apparently it is NLA. I have called all the usual places with no luck. Hoping that someone here has a source, or has one laying around that they would be willing to part with. Good used would be OK too. Thanks.
  2. VeloceSpace
    VeloceSpace Rookie
    Sep 4, 2009
    20
    Looks like you missed us as a source!
    We have two sets of these seals arriving in the next two weeks. They're $237.81 for the pair. If you'd like them I'll reserve for you.
    Thanks.
    Patrick Hung
    VeloceSpace
    www.velocespace.com
    [email protected]
    (408) 441-7788
  3. ztarum
    ztarum Formula 3
    Mar 30, 2008
    1,302
    South Jersey, USA
    Thanks Patrick, but I already spoke with one of your employees before I posted here. She informed me you were out of stock, but would order more. When she ordered some new sets from your source, they replied that they were NLA. Thanks anyway.
  4. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,066
    Kansas
    Sean F
    Try Matt at Reoriginals.com.
  5. JOEL D.
    JOEL D. Karting
    Nov 2, 2003
    222
    Boston, MA
    Joel DeLuca
    there was two used window set ups on ebay this morning.
  6. ztarum
    ztarum Formula 3
    Mar 30, 2008
    1,302
    South Jersey, USA
    Already did.
  7. ztarum
    ztarum Formula 3
    Mar 30, 2008
    1,302
    South Jersey, USA
    I saw two GTS gaskets, but the GTB gasket I need is different.
  8. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    I'm pretty sure that they're different SX versus DX, but I've got a nice driver's side trim piece for a GTB...
    David
  9. Futureman
    Futureman Formula 3
    May 16, 2007
    2,024
    So I'm assuming you've pulled your leaky window? What details can you give?
  10. ztarum
    ztarum Formula 3
    Mar 30, 2008
    1,302
    South Jersey, USA
    It is the same gasket for both sides on the GTB. If you have one you'd be willing to part with I'd certainly be interested. I'l send you a PM with my email address.
    The window isn't pulled yet. I don't want to do it until I have everything in hand, so the car remains drivable. Both sides leak on mine. I have sourced one NOS gasket, but need one more. The gasket I was able to get is symmetrical in cross section, and is not very complicated. I suspect I might be able to locate something similar and fabricate my own if need be. I will measure up what I have and post the dimensions.
  11. Futureman
    Futureman Formula 3
    May 16, 2007
    2,024
    I was under the impression that if the gasket wasn't damaged you could reuse it. Seems like I read somewhere that someone was able to reuse the gasket after they resealed the interface with the frame.
  12. ztarum
    ztarum Formula 3
    Mar 30, 2008
    1,302
    South Jersey, USA
    Normally you could, but my gaskets are breaking apart. The outside half of the gasket is splitting from the inside half and is coming out on one side . On the other, it seems to still be all one piece, but the rubber is folded under the glass in a couple of places. It's likely been like that for 25 years, and I suspect it will not be pliable enough to salvage.
  13. ztarum
    ztarum Formula 3
    Mar 30, 2008
    1,302
    South Jersey, USA
    #13 ztarum, Apr 25, 2010
  14. Futureman
    Futureman Formula 3
    May 16, 2007
    2,024
    What's the status on this? Have you started the project? Any details or insight you can share?
  15. ztarum
    ztarum Formula 3
    Mar 30, 2008
    1,302
    South Jersey, USA
    Nothing yet. Might not touch it until winter. Having too much fun driving it now.
  16. kiesan
    kiesan Formula 3
    1,527
    Seattle
    Kie Robertson
    #16 kiesan, Mar 13, 2012
    2 new gaskets on the way Zach. I bought these 10 years ago from Ferrari of Seattle for my 328GTB that would seep water through the bottom of the windows when the car was washed. The glass guy I tried at the time got scared and was afraid to pull the glass. Instead he tried resealing them which made it better but not 100%.
    Hope they work for you.
  17. Albert-LP
    Albert-LP F1 Veteran
    8,177
    around Modena, Italy
    Alberto Mantovani
    #17 Albert-LP, Aug 21, 2021
    I'm resurrecting this old thread, as I need a rear quarter window gasket: does anyone know about a different supplier than Cicognani? they sell it only in pair and at a fortune, 342 euro: 400 USD.
    Thank you!
    ciao
