HELP! I need electrical diagram for my 308! | FerrariChat
Discussion in 'Technical Q&A' started by PeterS, Jan 4, 2006.
  1. PeterS
    PeterS Five Time F1 World Champ
    52,029
    Goodyear, AZ
    PeterS
    I still can't figure out why my fuel pump and fuse link under the dash is not getting juice. If somebody has an electrical schematic they could email to my mechanic buddy, Kris at [email protected]), I would be extremely thankful. I have a buyer for the car and really want to get this problem behind me!
    Thanks in advance, Pete
    PS: If the ignition switch has gone south, could this be the problem?
  2. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    The wiring diagram is in the owners manual, page 107 I think. I took mine to Kinkos and had it enlarged to 23" x 36" for $5.00. much easier to follow.
    If you don't have the manual do a search for it.
    good luck,
    Steve
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,546
    San Carlos, CA
    Mitchell Le
    #3 yelcab, Jan 4, 2006
  4. PeterS
    52,029
    Goodyear, AZ
    PeterS
    Thank you! I'll look for additional comments.
  5. PeterS
    52,029
    Goodyear, AZ
    PeterS
    This pdf is not good, as it only shows a snapshot of some traces. Can anyone else please help me out?
  6. dm_n_stuff
    Dec 10, 2003
    43,710
    26.806311,-81.755805
    Dave M.
    Peter, what year??
  7. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    Full documentation just e-mailed to Kris. Hope it helps.
  8. PeterS
    52,029
    Goodyear, AZ
    PeterS
    Thanks (DM_N also). Do you know which relay is for the fuel pump? (Duhhh..I should have checked this out first!). My manual is in Italian and I'm looking for 'fuelio' or something like that!
  9. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    The correct term in Italian for fuel is 'benzina' or 'carburante'
  10. Ricambi America
    Sponsor Owner
    I have an 81 GTSi wiring diagram on PDF. Would that help?
  11. PeterS
    52,029
    Goodyear, AZ
    PeterS
    Thanks. Nuvolari emailed it to my buddy Kris, but I would appreciate if you could email me the copy you have to [email protected]. I DID find a disk with a fuse and relay diagram in English. I did not notice a relay for the fuel pump. Correct?
  12. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    #12 spiderseeker, Jan 6, 2006
    I have an 85 308 gts- and I think yours should be similar, if not the same, as far as relays are concerned-my fuel pump relay is the lower left one- see attached.
    Steve
  13. yelcab
    Nov 29, 2001
    13,546
    San Carlos, CA
    Mitchell Le
    #13 yelcab, Jan 6, 2006
  14. Steve Magnusson
    26,764
    Correct -- no fuel pump relay on a carb 308 (because the carb fuel pump doesn't need 10A to run).
    One more time ;) -- the first thing to check is if the azure wire going to the top of fuse #2 is at +12V when the key is "on".
  15. Ricambi America
    Sponsor Owner
    Shiddle... didn't see this thread until today. Sending the PDF now.
    Sorry it took so long!
  16. PeterS
    52,029
    Goodyear, AZ
    PeterS
    Thanks for everyone's help! It's fixed! It was the fuse block (Damnit!). The bank of three left fuses have a copper buss bar. That bar was loose! So it does not happen again, I'll probably just get a new fuse block and never have this problem again!
  17. Ricambi America
    Sponsor Owner
  18. PeterS
    52,029
    Goodyear, AZ
    PeterS
    Can you:
    1)Confirm this is the one on the left?
    2) Is that a good price? Seems a bit pricey.
  19. PeterS
    52,029
    Goodyear, AZ
    PeterS
    I just put in a new fuse block and BINGO! I had a perminant loose terminal spade on #3 that wiggled. The new $115 fuse block took care of the issue!
    Thanks for all the replies and help.
