Help identify Fluid | FerrariChat
Help identify Fluid
Discussion in 'Technical Q&A' started by dsd, Jan 19, 2016.
  1. dsd
    dsd F1 Rookie
    Nov 19, 2006
    4,284
    Northern Virginia
    #1 dsd, Jan 19, 2016
    The below photo was taken from under my 2011 Jaguar. Its a teal blue from mid front, under the engine.
    Only thing I can think is wiper fluid, but it seems too thick and dark. And not quite Anti-Freeze color (that I know of).
    I will call the dealer when I get back in town but any insight would be appreciated.
    Thoughts?
  2. tazandjan
    39,318
    Some synthetic ATFs look like that. Used in power steering systems, too.
  3. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,284
    Illinois
    There are not too many fluids to check on. Radiator (usually green), brake (clear to I think blue for some brands), Windshield washer fluid, oil (not blue-green) and transmission fluid. Check the fluids for color and identify which one it is or could be.
  4. Schatten
    Schatten F1 World Champ
    Apr 3, 2001
    11,238
    Austin, TX
    Randy
    BMW hydraulic/power steering fluid? CHF11S
  5. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    #5 finnerty, Jan 21, 2016
    Yep --- likely sources.
    Ruling out wiper fluid and coolant is a simple matter of popping the caps and visually comparing what's in there to what's on your floor.
    You can also pop the cap on your PS reservoir to compare that. And, you can pull your AT dipstick, and wipe it with a white cloth to compare that as well.
    There will only be one fluid in your car that matches such a vivid / distinctive color, and no other fluid will even be close ---- it will be incredibly obvious which one it is.
  6. PAP 348
    Dec 10, 2005
    100,234
    Mount Isa, Australia
    Pap
    Doesn't BMW use blue coolant? Pretty sure my Brothers 2005 750Li has blue engine coolant in it.
  7. North bay tech
    Apr 18, 2015
    22
    Fountain Hills, AZ
    Josh Bare
    That is most likely coolant. Many of the newer cars have switched to the blue coolant, even many Ferrari's are running it. Make sure to check your levels and good luck!
  8. scudF1
    scudF1 F1 Rookie
    2,919
    Long Island, NY
    Billy
    Seams coolant to me..
