Help identify this wire and device | FerrariChat
Discussion in '206/246' started by solly, Jun 10, 2013.
  1. solly
    solly Formula 3
    Jun 2, 2001
    1,148
    Westchester NY
    Dr. Steven S.
    #1 solly, Jun 10, 2013
    Pulled the airbox for a cleaning and filter change. Found a wire I can't identify. It comes off the bundle strapped to the firewall just behind the dipstick, then splits into 2 wires. One is a female spade connector not attached to anything. Nor does it look like there is anything nearby it could connect to.
    The second goes to a connector and emerges as a thin white wire with a black stripe which then connects to some device (sensor?) with a gold/black top just in front of and below the left carb (for cylinder #3). I checked the repair manual but I'm terrible at reading electric schematics.
    I am attaching pics. Thanks for any help.
  2. possum
    possum Formula Junior
    Sep 27, 2008
    307
    australia
    johnno
    Maybe the water temp transmitter?
  3. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,203
    Norfolk - UK
    Tony
    That's the water or low oil pressure transmitter, cannot remember which.
  4. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,643
    Toronto / SoCal
    Rob C.
    The gold sensor in your photo is the oil pressure sender.
    The other wire looks to go to the water temp sensor that is located on the forward head between two spark plugs. It will look like a hex head bolt with a male spade connector coming off the middle of it.
  5. solly
    solly Formula 3
    Jun 2, 2001
    1,148
    Westchester NY
    Dr. Steven S.
    Thanks all. All my gauges are working and accurate so possibly that unattached female spade goes to a sensor not hooked up to a gauge (maybe an idiot light sensor?) Any way, it's been this way for at least 12 years and everything seems to be working fine, so I'll just wrap the wire in self vulcanizing tape to protect it. Seems very fragile.
    This started out as as simple oil change and tuneup. Now I'm going nuts trying to make sure there are no loose connectors, dangling wires, and changing oil and air filters. Going to try the K&N filter and see if it makes any difference.
    I did find that the hose from the air canister filter to the airbox horn had partially slipped off the horn. My carbs were sucking unfiltered engine air. And this engine was rebuilt only 1200 miles ago. There was no clamp in sight, and because USA cars have that complicated oil pressure-activated flap in the horn (which I hope everyone has removed and plugged by now-it's dangerous) the hose only goes onto the air horn about an inch before butting up against the oil pipe bung. Not a lot of room to secure a hose to. Almost makes me want to spend the $600 or so for a Euro airbox without the bung. Came very close to pulling out the dremel to grind it off but that might create other problems like air leaks.
    Thanks for the help.
  6. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,750
    Berlin, Germany
    Adrian
    The unconnected wire looks like the oil pressure sensor to the red pressure warning light wire as you have already assumed. The wire color should be grey. The oil pressure switch is installed from below on the 'L' shaped pipe coming from the oil filter base and going to the tube from the heat exchanger.
    Sometimes when the 'L' shaped pipe/tubing is exchanged, a replacement without the socket for the oil pressure sensor is installed, resulting in the disconnected sensor wire.
  7. ferrarioldman
    ferrarioldman Formula 3
    Professional Ferrari Technician Silver Subscribed
    Jun 19, 2002
    1,035
    Summerfield, NC
    Tom Jones
    #7 ferrarioldman, Jun 13, 2013
  8. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    Wow! Some avatar!!
  9. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    That stone needs some Green Green Grass of Home around it........it's Not Unusual!
  10. solly
    solly Formula 3
    Jun 2, 2001
    1,148
    Westchester NY
    Dr. Steven S.
    Thanks Tom. What does that sensor do? As I mentioned, all gauges are working, as is the red low pressure oil light which comes on briefly when I start the car. So what is not being monitored with that connector hanging loose?
    Another question: What does the "crankcase pressure limiting valve" actually do? I've seen cars with airbox removed and individual filters placed over each carb. I assume they just plug the main hose and the 2 small manifold hoses?
  11. ferrarioldman
    Jun 19, 2002
    1,035
    Summerfield, NC
    Tom Jones
    It's a hobby. findagrave.com
  12. ferrarioldman
    Jun 19, 2002
    1,035
    Summerfield, NC
    Tom Jones
    That is the coolant temp sender. Maybe take your wire and ground it with the key on and watch your gauges to see if something happens. Is there anything connected to your sender?
    Crankcase ventilation. (Like a PCV)
    What year is your car?
  13. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    Tom Jones fan?
  14. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    Thanks. Slightly off topic question
    In the end was it the grave of Richard III they found?
  15. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    Not particularly,but its nice to know that he is on this site!
  16. dinogts
    dinogts Formula 3
    "Nice to know that he" - he who? - Tom Jones - or a Tom Jones fan - "is on this site"? ;)
  17. dm_n_stuff
    Dec 10, 2003
    43,782
    26.806311,-81.755805
    Dave M.
    Tom is a Ferrari mechanic. Which really doesn't do justice to Tom, but I don't know how else to describe him.
    He has quite a solid reputation as a top notch wrench. there, that's a little better.
    And he can carry one hell of a tune as well. :D
    D
  18. swift53
    swift53 F1 Veteran
    8,375
    E.S.
    Alberto
    I know him! It's not unusual, to hear of him in the right circles...:)
    Regards, Alberto
  19. swift53
    swift53 F1 Veteran
    8,375
    E.S.
    Alberto
    My Dino has a Tom Smiths fan. I really ignore if the same.
    Regards, Alberto
  20. champtc
    champtc Formula Junior
    Apr 18, 2004
    732
  21. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    don't know Tom smith, but if they sound the same way, as they get old, I'll pass
  22. ferrarioldman
    Jun 19, 2002
    1,035
    Summerfield, NC
    Tom Jones
    Afraid I'm not familiar with that.
    Poor Solly. He was just looking for a little help with a wire..........
