Help Identifying Part # for Gasket | FerrariChat
Discussion in '348/355' started by sgtpeper, Jul 6, 2020.
  1. sgtpeper
    sgtpeper Formula Junior
    May 4, 2004
    426
    Denver
    Jeff
    I'm trying to find the part number for the front rubber gasket for my GTS - the part that the front of the targa rests against.
    Any help is greatly appreciated.
    Thanks,
  2. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    From your description, my best guess is that you are talking about Tav 105, item 11, part number 62110800, "Windshield upper crosspiece trim, valid for GTS & Spider". Availability? Supply/Demand? Good luck!
  3. sgtpeper
    May 4, 2004
    426
    Denver
    Jeff
    I'm not so sure. We originally ordered - 63617800 - which almost fits but seems to be just for the Spider?
    We have now ordered 64338800 which seems to be the same part but for a GTS?
    The spider part seemed to just be a bit different at the A-pillar which is odd.
  4. A348W
    A348W Formula 3
    Jun 28, 2017
    1,856
    North Wiltshire, UK
  5. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Yep spider and Targa have different weather stripping including along the door sills, for the 348 the spider stuff is out there for the Targa not so much, typically used is what you find. :(
  6. sgtpeper
    May 4, 2004
    426
    Denver
    Jeff
    I found that one. Euro spares has it for about 900 us. I ordered that one. I'm just curious why the part was different for a spider but yet still mostly fit.
  7. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Interesting, so 63617800 for for the Targa? I suspect the junction between the A pillar and roof and window corner is where it is different.
    If it fit and sealed with top and windows that is very very good information to know. Can you confirm it fit or not?
    I bet the 355 part 64338800 also works for 348's, nothing changed there as far as I know.
  8. sgtpeper
    May 4, 2004
    426
    Denver
    Jeff
    64338800 is for the targa.
    63617800 - I was told sort of fit. It was loose at the A-pillar. Like a little thinner there.
