Help identifying wire / splice | FerrariChat
Discussion in 'Technical Q&A' started by Shox987, Jul 13, 2025 at 2:23 PM.
  1. Shox987
    Shox987 Rookie
    Sunday
    2
    Florida
    Patrick Salvant
    #1 Shox987, Jul 13, 2025 at 2:23 PM
    Hi i have a Novitec twin super charged 430 with
    KWS suspension. I need help identifying the function of this wire that’s spliced with some type of resistor . This is located on passenger side
    I also have a similar splice on same type of plug on drivers side light blue wire 2 yellow and green
    Red is plug blue is resistor /same as above different angle.
    Is this skyhook related ? My suspension light does flash
    BELOW unmarked box that was spliced onto skyhook harness to same wires scudding Swiss uses to turn off suspension faults think it’s a Novitec device ? I pulled it installing the scudding Swiss
  2. Qavion
    Qavion F1 World Champ
    14,259
    Ian Riddell
    #2 Qavion, Jul 13, 2025 at 5:03 PM
    I know what the plug is, but I'm missing some wiring diagrams, so can't identify the wires.
    On the left hand side, the violet wire carries power for the MAF.
    Would you be able to get a list of the wire colours (with stripe colours)?
    XR38 (cabin side)
    1 Green &? (possibly 28v coil and injector power)
    2
    3
    4
    5
    6
    7 Violet
    8
    9
    10 Light blue
    11 Yellow/blue stripe?
    12 Black
    YR38 (firewall side)
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    11
    12
    It may or may not help.
    Snapshift likes this.
  3. Shox987
    Shox987 Rookie
    Sunday
    2
    Florida
    Patrick Salvant
    Thanks for reply
    it’s definitely the XR 38. Plug / left
    Is the right an XR 38 plug also ?
    i just got the car and it’s shocking to see wire harness spliced
  4. Qavion
    14,259
    Ian Riddell
    Sorry, not sure what you mean. Are all your photos of the RH plug?
    The RH plug is called "XR/YR38".
    The LH plug is called. XL/YL38
    It's what the wiring diagram call them, not the type of plug.
