any suggestions? removed the two 8mm fasteners and it won't budge. thanks
I used a very small flat screwdriver (optical size) to gently pry between the filter and the gearbox. The o-ring is causing the "stiction".
If the screw is not stripped and nut is turning then nylon is might holding the nut. May try pulling and turning the nut with your fingers Remove it.
