News
Help! ****ing key will not work on Daytona
Discussion in 'Vintage (thru 365 GTC4)' started by Juan-Manuel Fantango, Aug 23, 2019.
  1. Juan-Manuel Fantango
    8,214
    Juan
    #1 Juan-Manuel Fantango, Aug 23, 2019
    crinoid likes this.
  3. BigTex
    Rossa Subscribed Owner
    Dec 6, 2002
    74,307
    Houston, Texas
    Bubba
    OK deep breath!
    I have had a lock failure like this...but FIRST.....do some trouble shooting.
    IF the steering wheel is turned off center, it imposes a stress on the lock rod, that runs between the switch and the column!
    So, go back, and while GENTLY pressuring the wheel back and forth, see if one direction or the other will unbind the rod and allow the switch to turn.
    This lock rod/column switch thing is long NLA, so be GENTLE with everything!
    More to follow....
  4. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    6,772
    So. Cal
    Armen
    Maybe turn steering while wiggling key?
    BigTex likes this.
  5. BigTex
    Dec 6, 2002
    74,307
    Houston, Texas
    Bubba
    Second possibility:
    Based upon the wear of the key, and the related "rooftop" pins that ride in the lock assembly, in four or five little vertical cylinders, on springs...it's possible one of them decided to go walkabout, and has left the vertical bore and is lodged loose against the key in another spot, jamming the whole thing and not allowing the switch to turn, as all of these pins, of various lengths, align nested into the key cut, and allow the switch to turn.
    That's how the lock works.
    This is also indicated if you cannot retract the key. Jiggle the key shank vertically up and down, forcing it to turn is no good and eventually the key will break off fluch in the lock, as my Body Shop was kind enough to do, in my car.
  6. BigTex
    Dec 6, 2002
    74,307
    Houston, Texas
    Bubba
    So, from where you sit, out in the lawn, IF nothing works as above, to get the wheel lock to unbind, or release the immobile key from the ignition switch, it's time for some heavy lifting.
    Lying on your back under the dash, you will have to remove the lock/switch/rod, as an assembly, because that's how the part comes out.
    Once the rod is out of the column, the steering wheel will unlock, you can move the car around by hand.
    A Safe and Lock guy, a good one, will drive a hidden pin out of the lock, freeing the inner assembly of rooftop pins, springs, and sh*t will fly all OVER the counter top. Then it's necessary to inspect the vertical bores, that tend to wear enlarged, especially at the shorter rooftop pins. You may need a new part, at this point.
    But, in my case, he decided that if he used longer rooftop pins, that nested deeper into the bores, the old part could be reused.
    After doing that, and rearranging them into a Best Case scenario, he then cut a set of new keys, which of course are far different from those older ones.
    Put it all back together, throw all your old key sets away, and your original Factory Codes, if you have them, are meaningless.
    If you have to get to this final step, it's because one of the short rooftop pins has broken out of the bore, and there's not any way to avoid the repairs described above.
  8. BigTex
    Dec 6, 2002
    74,307
    Houston, Texas
    Bubba
    ..and put some antibiotic ointment and BandAid on that finger.
    :D :D :D
    Daytonafan likes this.
  9. Juan-Manuel Fantango
    8,214
    Juan
    #7 Juan-Manuel Fantango, Aug 23, 2019
    Well...I just discovered i don't deserve to post here. In fact I deserve to be banned just on the grounds of simple Stupidity. Turns out I had a friend helping me with the shoot. After fing with it in the South Carolina heat and humidity for about an hour, my friend said do you have another key? Yes, in fact. But this key started it fine. So I got the other key. Tom put it in and it did not work. As he handed me the key I asked him to try it again. This time it worked! And knowing I posted this like a hot head I instantly felt like a fool. So it is the old worn key switch story. Geez.... Image Unavailable, Please Login
    of2worlds, Jack-the-lad and crinoid like this.
  10. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    6,772
    So. Cal
    Armen
    Ooops, I did not see your post before mine. Sorry. You explained it much better.
  11. BigTex
    Dec 6, 2002
    74,307
    Houston, Texas
    Bubba
    Looking at that upper key that quit working compared to the lower one, you can se my point.
    That upper key has the Codes it's the OEM key from the factory, and it's worn as smooth as a pork rib bone, after I knaw it down!!
    Far better a new key cut than the procedure I described above, which takes at best, three days!!
  13. BigTex
    Dec 6, 2002
    74,307
    Houston, Texas
    Bubba
    I have scars on my back from this procedure!!
    PS Not really, as it was JRV on his back, under the dash on my misadventure.
    "They say" you are not supposed to lube a lock, but I use a dry graphite into mine......
    Who cares what they say!!
    :D :D :D
  14. Juan-Manuel Fantango
    8,214
    Juan
    That's how frantic I was. That was caused by continuously turning against the wrong key.:cool:
  15. Jack-the-lad
    Jack-the-lad Four Time F1 World Champ
    47,568
    Isle of Luci
    Jack
    I'm glad it came to a good ending regardless. Don't worry...we all push the panic button occasionally.
    srslusso likes this.
  16. srslusso
    srslusso Formula Junior
    860
    Encino,Ca.
    Steve S.
    Does Julie know you are out fooling with her Daytona? She will now
    Jack-the-lad likes this.
  17. Juan-Manuel Fantango
    8,214
    Juan
    Haha of course. I'm her valet, stevedore, and le mari! I often go by the French/Spanish name of Dr. Valet Stevedore, or for you just call me Juan. Getting ready for the Hilton Head Island Concours, come join us. BTW, this Daytona is a driver, no concours queen, just the way it should be. Oh, I forgot to add copilot and boat captian the the mix....
  18. Patek
    Patek Formula 3
    1,760
    Georgia
    John Milton Denton
    I am starting to worry about you David......
  19. Juan-Manuel Fantango
    8,214
    Juan
    Me too...look at the disapproving looks I got as I pulled the car in. I though about you the other day, how you been? When you coming down the mountain to see us? Image Unavailable, Please Login
  20. Juan-Manuel Fantango
    8,214
    Juan
  21. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    6,772
    So. Cal
    Armen
    Well... It seems the end result is worth it. Great shots.
  22. malcolmb
    malcolmb Formula Junior
    Apr 17, 2002
    986
    San diego
    Malcolm Barksdale
    Note that I haven't said a thing.....Malcolm
  23. Juan-Manuel Fantango
    8,214
    Juan
    #20 Juan-Manuel Fantango, Aug 28, 2019
    Julie says Hi Malcolm!
  24. Patek
    Patek Formula 3
    1,760
    Georgia
    John Milton Denton
    David, I miss seeing you and Julie. Hope you fly over the top of the house sometime. I did meet a lady in Highlands a few weeks, she saw the Ferrari and said do I know you and Julie. I said "of course not", didn't want to do myself in before I heard the rest. I assumed you had done something in Highlands that is still talked about to this day.... wasn't sure. But her husband is the pilot that lands in your Lake during the Ferrari Fest we use to have at your house. By the way, are you back in the house.
    Best,
  25. Juan-Manuel Fantango
    8,214
    Juan
    #22 Juan-Manuel Fantango, Aug 28, 2019
    View attachment 2817784 View attachment 2817785 View attachment 2817793 View attachment 2817794
    Lol, yes we have blazed a trail through Highlands a time or two and we miss the good times for sure and you guys. It is a evolution so to speak. Have not moved in but there almost every day. I believe the property should be commercial, something for a greater good or use so it is something we are discussing. Two people living there did not make a lot of sense, but living in what I would call art was fulfilling. Here is a picture that was taken just before the fire and the great eclipse, ergo the goggles. You can see the curvature of the house from this shot. There are not many straight lines.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Patek likes this.
  26. Juan-Manuel Fantango
    8,214
    Juan
    ok, so back to the keys, and what might seem like a really dumb question. Can you order a cut key for a 1971 Daytona? So if it is worn down, how to you get it cut properly? A link would be very helpful, in the meantime I will do the search bar.
  27. SCantera
    SCantera F1 Rookie
    2,793
    Living Falls NC
    Starting????
    Have you ever been a passenger in a car David was driving? Or tried to follow him? I once kept 10 Ferraris in an orderly fashion to exit I40 on our way to lunch. David broke from the back of the pack blew by me and nearly missed the turn.
    I have known David for a long time. I am still and probably always will be worried !
  28. SCantera
    SCantera F1 Rookie
    2,793
    Living Falls NC
    There are repro blanks you can buy. Any qualified locksmith can cut it for you. I have a real original Niemann blank. I will trade a week with the F40 for the blank.
