help installing a challange grill | FerrariChat
Discussion in '348/355' started by van22, Sep 30, 2006.
  1. van22
    van22 Karting
    227
    Absecon Island, New Jersey
    VAN C
    just got my challange grill today and need some help to install. have taken off all of the bolts excep for the 2 top center bolts which are hidden behind the third brake light trim. do i need to drill out the 2 pop rivets on either side to get that trim off and have access to those bolts? any and all help appreciated
    thanks van
  2. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,973
    MD and NE
    Robbie
    Not that it helps you now, but I am doing a step by step pics and all when I install mine. I have the grill just don't have the car until the 10th of October...
  3. van22
    van22 Karting
    227
    VAN C
    thanks, i drilled out the pop rivets and it all came apart. took me 2 and half hours but feel great. algar wanted a couple of hours labor to do it. love those guys but sometimes you just have to wonder?
  4. 285ferrari
    Sponsor
    Sep 11, 2004
    20,973
    MD and NE
    Robbie
    May be calling you when I get mine statred
  5. van22
    van22 Karting
    227
    VAN C
    no problem, the only thing i had to leave my garage for was a smaller pop rivet then the ones i had.
  6. 285ferrari
    Sponsor
    Sep 11, 2004
    20,973
    MD and NE
    Robbie
    Post some pics when you are done---luv to see it
  7. IanMac
    IanMac Formula 3
    Jul 26, 2006
    1,455
    Scotland
    Ian
    What is there to wonder about? It took you two and a half hours, they said they'd do it in two - sounds very reasonable!
  8. f355spider
    f355spider F1 World Champ
    18,053
    Rats, wish I had seen this sooner! I would have recommended that you go out and purchase 7 new Sylvania 2723 bulbs and change them all out on your third brake light, that way you could save yourself from having to drill those rivets again in the future to get in there to fix a burned out bulb.
  9. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Where does one get the black pop rivets from??
  10. f355spider
    18,053
    Just use regular ones...then use a little Testors gloss black modeling paint to make them black. If they were in a more visible location, then I would get the proper black ones...but they are largely hidden, so a little paint works fine.
    If you search the archives, there are posts on sources for black rivets, as they are used on various model Ferraris to hold A-pillar trim, the rear engine lid grills, etc.
  11. BrianC
    BrianC Formula Junior
    Apr 6, 2004
    908
    North Augusta, SC
    Brian C
    #11 BrianC, Oct 4, 2006
  12. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Nice pics! So removal of only one fastener is required for access?
  13. BrianC
    Apr 6, 2004
    908
    North Augusta, SC
    Brian C
    That's correct (at least with my car). Remove one fastener, carefully slide the hinged piece open, remove the mesh piece and 3rd brake light, then slide the hinged piece back in place while continuing the job. As long as it's in the "closed" position... there's less chance of bending it.
  14. 285ferrari
    Sponsor
    Sep 11, 2004
    20,973
    MD and NE
    Robbie
    Just finished installing mine---if anyone needs help let me know while it is fresh in my mind. Was going to post pics, but the tight quarters getting to the nuts won't allow camera space..
