Help interpreting Technicians report | FerrariChat
Discussion in '348/355' started by ricmat, Oct 27, 2016.
  1. ricmat
    ricmat Formula Junior
    Aug 29, 2016
    345
    London, UK
    Ricardo
    Hi all,
    Found this F355 I have been looking at.
    Car is a 97 B (5.2) with 47k miles. Car seems to be in good condition and has several maintenance receipts (i have not yet seen the car in person).
    Last cambelt service was in 2013. Car had 2 services since then.
    Very last service included
    - fluids changes;
    - replacing released bearings and seals"
    - replaced cracked wheel inserts on both OS alloy wheels
    - replaced both inner CV boot gaitors as split
    - replaced rear brake shoes
    but after all that, there's a technicians' report in the end that mentions:
    "further / potential works:
    - Bonnet struts weak
    - both reat inner wheel arch liners cracked
    - wheel spacers fitter to car
    - both entine mounts starting to drop
    - oil pressure gauge intermitently not working. requires further investigation, but suspect possible wiring fault in loom or gauge. oil pressure is fine on car"
    Can someone please share thoughts on this, whether this could uncover any potential issues?
    Many thanks in advance
  2. plugzit
    plugzit F1 Veteran
    7,786
    Redondo Beach, CA
    Bruce Bogart
    Looks routine.
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,641
    San Carlos, CA
    Mitchell Le
    The last service was not very much more than draining some fluids. As far as the cracked liners, wheel inserts, engine mounts... they ALL do that. That is very very routine.
  4. bikz
    bikz Formula 3
    Mar 2, 2012
    1,043
    Malaysia
    prima facie car seems fine......nothing serious....get a PPI done esp on the engine compression/leak down.....besides that check on the break pads/disks wear as well....
  5. Qavion
    Qavion F1 World Champ
    14,465
    Ian Riddell
    Or the oil pressure sender (below the oil filter). I found one of the electrical connections on the oil pressure sender broken on mine (may have been damaged on the last engine out). I had to change the sender.... Relatively cheap to purchase. A 24mm spanner required and possibly a heat gun. Use a combination of penetrant, heat and muscle, but not too much muscle. The cast aluminium base is expensive to replace if it breaks. A copper washer came with the sender.
  6. PAP 348
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    All very easy fixes and nothing to worry about.
  7. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    as others have said.....no issues...just minor stuff that could occur on any used car.
  8. ricmat
    Aug 29, 2016
    345
    London, UK
    Ricardo
    Thank you all. To be safe I should probably budget a major with cambelt, water pump rebuild, new clutch and brakes I think..
    thoughts
  9. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,698
    South East
    Jimmie
    Wait til you've read the paperwork - it may be that waterpump and/or clutch and/or brakes have recently been done
  10. Enzojr
    Enzojr F1 World Champ
    Dec 12, 2013
    14,001
    West of PDX
    Tomy
    Good thinking to play it safe, all the potential stuff is fairly inexpensive.
    Struts are like $30 each, I just bought 4 new ones.
    Oil pressure sending unit is .... I think less that $200, replaced mine awhile back.
    Also if in London you should be able to find a F chat member with a 355 to go with you to see the car ;)
