Help Is this 308 noise something bad | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by BillyD, Jul 24, 2007.
  1. docweed
    docweed Formula Junior
    Dec 8, 2004
    452
    Morgantown,WV
    Chuck Stewart
    Hope that's not some object stuck in your cam-belt. See the white thing in the belt in your picture.
  2. wolftalk
    wolftalk Formula Junior
    Jan 27, 2004
    367
    san franciso area
    phil
    wrong end of the engine
  3. fatbillybob
    Aug 10, 2002
    29,380
    socal
    Noises travel pretty far especially through metal. So you really need to use the mechanic stethescope and sometimes you can actually feel the noise through your hand too as you hold the stetchescope pointer. If you don't have a stethescope put klenex in one ear and the handle end of a long screwdriver in on the other ear. Then give a listen to narrow down the source. If you think it is a tensioner bearing they have rubber seals. You can actually fill a hypdermic needle with grease and poke the grease seal and regrease it. If the noise stops you confirmed the diagnosis. Out of position cams can also cause more valvetrain noise. Using external cam locks are more likely to cause cam timing problems because the only way to confirm true cam timing is with a degree wheel and dial guage or factory marks as second best. And a Throw out bearing is really not a crazy idea. Sound can travel and really fool you at times. That's why you need to stethescope it to really narrow it down otherwise guessing is costly and time consuming.
  4. DKHudson
    DKHudson Formula Junior
    Sep 1, 2004
    438
    Durham, UK
    David Hudson
    I haven't been able to check out the YouTube posting (that web site is blocked from my office)...
    However, I had a really nasty noise from the cam belt area, harsh metallic, rather like dry bearings. This noise was originally over 5000revs and then progressed to start lower and lower down the rev band.
    It turned out to be a crack in the alloy cambelt cover runing from one of the fixing holes. Sympathetic vibration was causing the cover to resonate and the edges of the crack were grating against each other, causing an awful noise.
    May or may not be relevant in this case, but easy to check and none critical if this is found to be the culprit. Just remove one cover and try the engine to see if the noise goes away. Then remove the other cover etc.
    My cover was repaired using resin repair about 2 years ago and is still holding okay.
    David
    308 GTS carb
  5. BillyD
    BillyD Formula 3
    1,838
    Pacific Northwest
    Bill
    Well I ordered 2 bearings #104917 which superseded #101299, 2 ringnuts & an $85 tool to remove the ring nut. Oh yeah, 2 new timing belts too. Only thing I don't know about is the seal.
    Bill
  6. BillyD
    BillyD Formula 3
    1,838
    Pacific Northwest
    Bill
    Has anyone matched this seal from a bearing supplier?
    Looks like I'll have to make a bearing puller too as the Sykes is just a bit too pricey. I searched & found 2 home made ones here, one out of standard hardware bolts & another from 5mm ball allens, anyone else maybe with dimensions so I can build it while waiting for the ring nut tool to arrive.
    Bill
    ps sure wish the seal was leaking, I'd feel a bit more confident the bearing was the problem & I'm not wasting my time.
  7. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Stethoscope is a great tool (I've got an electronic one with headphones I can't stand those things poking my ears). It's amazing how it cuts right through the background noise to the source of the problem.
    I had a Miura with a clutch that made just that kind of noise unless the clutch release lever was adjusted "just so".
  8. BillyD
    BillyD Formula 3
    1,838
    Pacific Northwest
    Bill
    Its interesting all the people talking about the throw out bearing, the drivers side rear of the car is perfectly quiet but I have noticed lately that the clutch has been letting out right at the top. Hmmmmmm looks like I should put the belt back on & adjust the clutch cable to see if I can get it to go away.
    update: just put the timing belt back on, well actually I put on a different belt that I had run for about 20 miles 2 years ago so as to eliminate timing belt noise. I also checked the clutch adjustment, I don't seem to have any free play at the clutch bell crank. Being its an early 308 b4 the helper spring shouldn't there be some freeplay so the throw out bearing isn't spinning? No time to release cams & start her up right now so the suspense continues, sure would be nice if it was the throw out bearing!
  9. wolftalk
    Jan 27, 2004
    367
    san franciso area
    phil
    yes. The adjust procedure is the same as the one in the gt4 workshop manual you can find on the net.
    standard disclaimer - the above applies to unmodified carbed 308's and some early gtsi's. If the arm on the bell housing as a big spring on it, or just look under the dash- if there is a stop/bracket above the clutch pedal preventing it from raising higher, you care about free play
  10. RGigante
    RGigante F1 Rookie
    Owner Project Master
    Nov 1, 2006
    2,874
    Portugal
    I had a very similar noise on my 328. It would only happen when dead cold and would go away after about 30 seconds to 1 minute.
    The problem was the A/C compressor. Since it didn't work anyway I've removed the belt et voilá, problem solved. The stethoscope was essential to find the source of the problem.
    And yes, the compressor (and all A/C system) will be reconditioned before next summer :)
  11. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Are you positive it's not the belt, rather than the compressor making the noise?
    It's very common on the 308/328 for the belt to make a clicking noise for awhile, and then disappear. It will do it especially on humid days, and after cold starts.
    Check it out, you might save a few bucks.
  12. BillyD
    BillyD Formula 3
    1,838
    Pacific Northwest
    Bill
    The correct answer to the source of the noise is:
    "Normal timing gear noise" ala a whole lot of stress, & Carlo of Alfa of Tacoma (the local Ferrari expert)
    Carlo said the engine sounded good tho the carbs were out a bit.
    Thanks to everyone for their suggestions & I hope this post helps someone else in the future.
    Bill
    sipping the tequila as the stress melts away (my Car is OK, my car is OK, my car is OK...................)
    ps you can't hardly hear this noise from the top, u have to have wheel well out & listening head on
  13. Glassman
    Glassman F1 World Champ
    What!!! The sound I heard on the You Tube is not normal timing gear noise. I think you might need a second opinion.
  14. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
  15. Jdubbya
    Jdubbya The $10 Trillion Man
    44,010
    Hell's waiting room
    Sorry guys but I can tell you if Carlo says it's normal I'd be more than inclined to believe him! One of the most honest and experienced mechanics anyone could ever ask for!!
    That's great news Bill. Now if I could just get an appointment with City Glass my car would be done and we could go drive them together!!
  16. fishing
    fishing Karting
    Sep 3, 2006
    137
    Norway
    Harald
    I think it's one valve or lifter is making the noise.
  17. MRFOTOS
    MRFOTOS Karting
    May 26, 2003
    232
    Maui, Hi
    IMO if the sound goes away when warmed up, It may be an oil isues,first off verify your are not down a quart or two.
    Are you running 20W50 or 20W60
    as I have heard some f-chatters may be using, next oil change , try a different viscosity if your already running 0W50 then disregard
    if not then try this 0W50..
    http://www.evasivemotorsports.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=ENEOS0W50&Category_Code=ENEOS&Store_Code=EM
    a bit expensive... but cheeper than having a F-cert mechanic spend a couples of hours trying to diagnose what might be a simple oil issue
  18. wolftalk
    Jan 27, 2004
    367
    san franciso area
    phil
    the thing I never considered when listening to the video was how close to the engine the microphone was, and the effect of it being inside the wheel well area.
    the timing gears and tensioner bearings are pretty noisy if you stick a stethoscope on them. If that's what the mic was picking up, then "no problem found" seems pretty reasonable.
    besides, any time a mechanic tells you to keep your wallet in your pocket, I'd believe them :)
  19. Glassman
    If my car made that noise from oil starvation at start up, I'd be ****ting bricks.
