HELP, just bought a 2002 360 spider and it fail the emission failed! | FerrariChat
Discussion in '360/430' started by implantpower, May 7, 2013.
  1. implantpower
    implantpower Rookie
    May 4, 2013
    9
    Hi everyone! i just purchased a 2002 360 spider. This has been a dream car of mine since i could remember. it was very disappointing to fail emission! the ferrari tech told me its due to my after market exhaust by Fabspeed. I did some research and found that it maybe due to the catalytic converter or test pipes. I have two question:
    1- do i have to change the entire exhaust system or just replace parts, ie, the catalytic converters.
    2- I was looking into a capristo exhaust, what are all the parts i need to buy, or does they come complete system where the tech just install it?
    Thankyou everyone!
  2. RotarySwingGolf
    RotarySwingGolf Formula Junior
    Dec 24, 2011
    490
    Florida and Idaho
    If u have test pipes you'll need cats to pass emissions. I have some for sale in the for sale section that are oem with only 5k miles and they're cheap. PM me if interested
  3. rmani
    rmani F1 Veteran
    Nov 1, 2003
    7,334
    NJ
    RMani
    what state are you in. depending on how tough they are normally a small bribe will get you the sticker.
  4. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    If you are in CA and bought the car in CA, seller is responsible for smog!
    Jes
  5. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    maybe shoot a picture of the cats and headers so we can tell what has been done?
    any other details on why/how it failed? visual, sniffer, etc?
  6. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,454
    did it only fail visually?what state are you in?do you have a ck engine light on,more info
  7. jlonmark
    jlonmark F1 Rookie
    Mar 29, 2005
    3,203
    Beverly Hills, CA
    Jay
    Did you get the car "hot" first? I mean drive the heck out of it for about 1/2 hour. The 2000 and up pass pretty easily. I even get my 1999 360 with tubi to pass in CA
  8. jpk
    jpk Formula Junior
    Find out if your exhaust has catalytic converters or if they were removed. If they are there, then you just might need to run your engine up to full operating temp before taking the test. Cats work best when hot.
  9. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,733
    Just East of Weird
    Bob
    I had fabspeed headers and high-flow cats and was able to pass emissions. Do you have a local indy guy -or even the dealer - to check for codes before you get it inspected (CEL on -common with Fabspeed stuff). Then, as has been said, warm it up and put it though a couple drive cycles.
  10. blkdiablo33
    Jul 12, 2004
    4,454
    when i had my 01 360 passes with flying colors with upgraded exhaust with hi flow cats on it too.and no ck eng lights on
  11. djkling
    djkling Formula Junior
    Sep 28, 2012
    498
    Newfields, NH
    Domenic
    mine did this too, the dealer had me run it through "readiness' (where you drive it at different speeds for different times) to "reset" the computer or something. Went back for inspection and it passed fine!
  12. m2g2
    m2g2 Formula 3
    Aug 10, 2012
    1,383
    SoCal
    Mark
    When they sit around at a dealership for months waiting to be sold, the F-techs say that you need to drive them for some time as stated by the dealer. This gets the computer back into "happy mode." Also, as stated by the others, make sure it is hot when you bring it in for the test...the cats need to be heated up to perform at their highest level. As long as you do have cats on your car (and not test pipes), drive it as stated by the dealer and get the cats heated up, you should have no problem.
  13. implantpower
    implantpower Rookie
    May 4, 2013
    9
    I am in fairfax, virginia. I am having a local ferrari dealer check the code and for cats. than i will see whats going on. but my feeling is like most of what everyone is saying is to driving it a few time to get the cats "hot". Thanks again and i will followup if the engine light is off.
  14. tonino ct
    tonino ct Karting
    Mar 1, 2018
    140
    tony
    i am buying a 360 euro spec from California with caprisco exhaust,the car is registered in CA, should i be worried about the emission?
    i would need to pay sales tax before i do the emission and if i fail?
    please any suggestion? i live in CT.
    thanks
  15. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    You can look up its past CA smog history to see how it has fared in the past with passing CA smog: https://www.bar.ca.gov/pubwebquery/Vehicle/PubTstQry.aspx
    Smog test/history should also appear on the car fax.
  16. tonino ct
    tonino ct Karting
    Mar 1, 2018
    140
    tony
  17. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    Emissions testing...
