Help-Lost 4th gear! | FerrariChat
Help-Lost 4th gear!
Discussion in '348/355' started by Juan-Manuel Fantango, Nov 11, 2007.
  1. Juan-Manuel Fantango
    Juan-Manuel Fantango F1 World Champ
    14,924
    Juan
    yes, these gear boxes do suck, have blown one, know others who have blown them. That being said, I was warned mine was weak 15K ago. Just lost 4th synchronizer I think. It kicks back and grinds in 4th, and will go in if I ease it after trying several times. It just suddenly started doing this.
    Here is the question: I have a track day this weekend, what's going on internally? Metal floating around in there? Why all of a sudden? Stop now and rebuild or hammer it to destruction? Help-FatBillyBob and all you other gear heads on FChat!
  2. Dr_ferrari
    Dr_ferrari Formula 3
    Nov 2, 2003
    1,073
    Pocono Sportscar
    Jim McGee
    Sorry to say, Rebuild it now....If you continue and there is damage in the box, you will just make it much worse and much more expensive.
    If you need help, let me know.
    Best regards, Jim
  3. MaterMech
    MaterMech Formula Junior
    Feb 26, 2007
    476
    Los Gatos CA
    Mark Johnson
    4th gear syncro is probably wasted. How does it shift if you rev match? I don't think it's worth taking a chance at the track. If the syncro hub and or 4th gear is damaged you risk grenading the trans. If it's just the syncro ring you just have to be real good at rev matching. A gear box oil change is in order. Do you have silver glitter or bronze glitter???
  4. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Check your tranny fluid level first for reference. Then drain it hot (or let it drain cold all night). Look for metal in the fluid and on the drain plug.
    With the tranny drained, open the inspection plate and look up in there.
    Fill with gasoline or automatic tranny fluid. Turn a wheel forward by hand while in gear. Drain the gas or ATF (then add a little gear oil and redrain to make certain that you got all of the gas/ATF out). This should clean what can be cleaned easily, which will help a little.
    Refill with Redline Heavy Shockproof if you want to risk another day based upon what you saw above (double clutch and rev match 4th), otherwise might as well tear it down now if you see anything extreme or just want to play it safe.
  5. PAP 348
    Dec 10, 2005
    100,234
    Mount Isa, Australia
    Pap
    4th gear synchro is ****ed! :)
    I would tear the box down and fix it. Run it to destruction if you want to spend/waste more money. :)
  6. fatbillybob
    Aug 10, 2002
    29,272
    socal
    I never recommend people drive on known bad parts so I can't recommend. Me I would probably drive it on a trackday knowing I may cause more damage but also there may be no more damage. I would rev match aka heel toe downshift. Before I did anything I would check the shift linkage twice! People are blaming the gearbox all the time for really bad or sliping linkage adjustment.
  7. Juan-Manuel Fantango
    14,924
    Juan
    I can't seem to rev match it. Just will not go in gear at all. As for linkage, where can I look for adjustment here? I fear it is worse, rubbing sound with the car in nutural and motor running.
    Seems to me there is some sort of nut that wants to back off a shaft in the trans. This happened to me twice, never understood that. This came from the service dept at the dealer, what is this about and can it be send without taking the clutch out? Where is the inspection plate that was mentioned? I'll do a search as well. Thanks!
  8. Juan-Manuel Fantango
    14,924
    Juan
    Been reviewing threads, most questions have been asked before, but the news looks bleak to me thus far.
  9. fatbillybob
    Aug 10, 2002
    29,272
    socal
    if your diagnosis is correct that it is the gearbox making the noise you are done. Perhaps you could get really lucky and pull the GB and just tighten lockrings. OEM Ferrari says use 242 locktite and dimples the lockring into the shaft land and and unknown or controversial torque spec.. I do my own thing and have done it on several GB's 6 so far with no issues. I use 271 locktite at least 100ftlbs with a air tool like a mean tire monkey would do on your wheels with an airgun. Then I smash the ringnut lock ring into the shaft land so that the metal breaks into the land and therefore cannot backout. This sounds harsh to the uninformed but no GB I have worked on has failed yet and no lockring I have tightened has ever come out.
  10. Dincenzo
    Dincenzo Formula 3
    Oct 11, 2005
    2,434
    Columbia, SC
    Adrian
    Where is that nut located? Is it behind the plate on the back of the gearbox?
  11. Juan-Manuel Fantango
    14,924
    Juan
    Bad news...what do you think...
  12. Ricambi America
    Sponsor Owner
    #13 Ricambi America, Nov 14, 2007
  13. mseals
    mseals Two Time F1 World Champ
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    JEEPERS DANIEL.... was that from yours????
    Mike in Kuwait
  14. Ricambi America
    Sponsor Owner
    Yes. Imagine putting a 150+ $100 bills into a food processor, then press the CHOP button lots of times.
    It's just the tip of the iceberg however. I'm close to $37k for the year in maintenance -- and that's using parts at my cost, not retail. These cars are not for the faint of heart.
  15. mseals
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    Wow...I mean.... wow....
    Mike "almost speechless" in Kuwait
  16. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    What the heck did you replace?! That's a whole 348 TS at current auction prices.
    Could none of your major parts be repaired rather than replaced? ECUs? Engine? Tranny?
  17. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,804
    LA
    Frank
    $37K??????? It would have been cheaper to part it out and buy a 355. (Ducking and running for cover out of the country) :)
  18. Ricambi America
    Sponsor Owner
    I'll explain it all in a few weeks. Pain has no price... Or does it?
    There are at least two other Fchatters who have achieved equal pain in their 348's this calendar year alone.
  19. Oengus
    Oengus F1 World Champ
    Holy crap Daniel...............what can I buy from Ricambi to help ease the pain.
  20. GTHill
    GTHill F1 World Champ
    Jul 1, 2006
    14,054
    Double Wide
    GT Hill
    I'm not sure you are still going to drive it, but is there a risk of lockup during operation? I can just imagine a down shift coming into #3 hairpin, then... lockup.
    Gene
  21. Juan-Manuel Fantango
    14,924
    Juan
    #22 Juan-Manuel Fantango, Nov 14, 2007
    No, will not drive it now, it is sad, just before our event, but so be it. I spent over 40k this year, valves, lots of little things that added up, as well as paint. And to think I could have been buying Dino's for 40K, Daytonas for 80-125K, yadayada. But it has been more fun. Over 40,000 miles in the last 4 years, long trips to Indy, Watkins Glen, Sebring, VIR, lots of Blue Ridge driving and track. So you live one life, and this has been fun...
  22. speedy_sam
    speedy_sam F1 Veteran
    Jul 13, 2004
    5,559
    TX
    Sameer
    Sorry to hear about your misfortune. Hopefully your car will be fixed soon :(
    BTW I see you are a Peter Ustinov fan judging by your screen name :)
  23. gatorgreg
    gatorgreg Formula 3
    1,949
    NAPLES
    Greg Griffin
    #24 gatorgreg, Nov 14, 2007
    David, you should of been listening to Mario Grande, "Hey piccola David, you musta give'va gas when ya downa shifta!" He was telling you how to drive and me also. Yeah Right! You did fine!
  24. Juan-Manuel Fantango
    14,924
    Juan
    #25 Juan-Manuel Fantango, Nov 14, 2007
    Mario is a hoot!-a true Italian from the old country. We love to hear him talk. You guys need to get in that 414 and fly up to the Colonial Cup this weekend...I've got front row paddack tickets waiting for you.
