HELP!! Lost Fuel Door Key - 308 | FerrariChat
Discussion in 'Technical Q&A' started by Owens84QV, Aug 20, 2004.
  1. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,486
    Somewhere in NC
    Greg
    When I purchased my 308 ('84 Euro), the owner had only one key to the fuel door. Yes... I should have purchased another set of spare key blanks to cut a second set. Well...I have lost the set of keys with the Fuel Door key.
    Is there a special key and key code that I can look up or obtain to fix my dilema? Thankfully I have a full tank of gas, but still I can't drive it much until I find or replace the fuel door key.
    HELP!
  2. f355spider
    f355spider F1 World Champ
    18,044
    I imagine you are going to have to pick the lock (not hard) then remove the cylinder and have a new key made for it. You need a small thin piece of flat tin metal with "teeth" on it (use a pair of tin snips). "Rake" it back and forth, while turning gently with a small flat bladed screwdriver. Basic "lock picking 101"... ;)
    Fortunately the lock for the vent/fuel door is not very sophisticated, and easily defeated.
  3. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,486
    Somewhere in NC
    Greg
    I'd rather not have to try that...I'm not the most proficient lock picker...actually never tried it. I may have to call a locksmith.
    I'm about sick to my stomach by losing these keys!
  4. f355spider
    18,044
    It is really quite easy on such a simple lock...you may want to try a "google" search on lock picking...I'm sure there are some good DIY websites that teach the basics, and build your confidence in trying it. This stuff happens to people all the time....losing a key to a gym locker, suitcase, storage shed, etc.
  5. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Just drive it to a good locksmith and he can have it open in less than 2 minutes.
    By the way, my 308QV's louvers are keyed the same as the doors... you might want to have him do yours that way also. One less key to keep track of.
  6. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Just walk into any Ferrari Dealer, hand them your vin number, proof of ownership (title) and they can order a new set of keys for you. Central Florida Ferrari ordered a new set for my 308 and my Testarossa with no trouble.....my wallet had trouble though :)
  7. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    Curious... how much trouble?
  8. Lee Ashley
    Lee Ashley Rookie
    Dec 9, 2003
    15
    Augusta Georgia
    Lee Ashley
    I had a similar situation with a fuel lock on an old muscle car. If you drive it to a locksmith they will pick the lock and make a new key for you. I had to do it twice. They do it by the method described earlier and are very good. Took a total of a couple of minutes.
  9. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,486
    Somewhere in NC
    Greg
    Thank you everyone...I had already located a couple locksmith places to go to.
    Mike...my fuel door louver and opposite window louver have different keys! WTF? I knew this before, but still, WTF? Just doesn't make any sense...but then again, just another idiosyncrosy about these cars.
  10. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    On the 308 here the doors and gas/passenger louvers are the same key.
  11. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Chances are the previous owner had one changed out for some reason. Have them re-keyed to match your door key for convenience (as well as originality...). It will probably cost you only $5 per lock to have them redone to match your door key.
  12. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,486
    Somewhere in NC
    Greg
    Appreciate everyone's help! I'll have everything re-keyed to match the door key.
  13. f355spider
    18,044
    Excellent! So if I have this right....you had three of the smaller keys? One for the doors, and one for each window louver? Holy cow...never seen that before....definitely one (or both) of the louver locks must have been replaced.
    Strange.
  14. Mark 328
    Mark 328 Formula Junior
    Nov 6, 2003
    510
    Orange, Ca
    Mark Foley
    One time, when I first bought my 328 I was driving around with the spare set of keys (no louver key) and needed gas. I was able to gently force (by wiggling around) the louver door open with only my bare hands.
  15. CarlH
    CarlH Karting
    Feb 5, 2004
    81
    MD
    Carl H.
    At a past F-club event, one of the members had a door key get stuck in the door, and had no way to enter the car. Someone pointed out that Ferrari only made a small number of keys for any given model. Sure enough - someone elses key opened the other door. Might check your local Ferrari owners and check their keys. Long shot but I saw it work once.
  16. PeterS
    PeterS Five Time F1 World Champ
    52,116
    Goodyear, AZ
    PeterS
    The same holds true for Cessna! My 172 key could open about any plane on the ramp!
  17. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,486
    Somewhere in NC
    Greg
    Thank you for everyone's help. I took the morning off and went to the locksmith. They pryed the locks open, rekeyed the barrels (one key opens both louvers now!), and supplied three keys for $63.00. Not bad.
    It may have been a simple fix, but when you lose the only keys you have to the fuel door, you tend to panic.
  18. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    I think it was about 150.00 per 2 key set per car. It's only expensive after you get the key...the door opens and the problem is solved. :)
  19. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    There should be the same key for all doors and louvres.
    It's very easy and causes no damage to simply gently twist the louvre to unhook the lock tab. It's no big deal at all.
    Should definately get matching keys all round the car though.
    One possibility is that you car was in a paintshop at the same time as another GTS, and the louvres got swapped between cars by accident.
