help me solve the bad-sounding-360 problem... | FerrariChat
Discussion in 'New York Tri-State' started by noahlh, Jan 2, 2005.
  1. noahlh
    noahlh Formula 3
    Aug 28, 2003
    2,231
    NYC, NY
    Noah
  2. 993 guy
    993 guy F1 Rookie
    May 21, 2004
    3,066
    Bergen County NJ
    Eric D
    Wow Noah...that definitely doesn't sound kosher. Not that I'm an authorized Ferrari mechanic but I do have a history working on various cars and you have a exhaust problem for sure (as opposed to mechanical...I know the statement sounded obvious after I wrote it). The sound that you're hearing may not be coming from the "exhaust" though and may be coming from the connection of exhaust manifold to the headers themselves (bad connection/seals). It could also be a leak somewhere along the way on the "topside" of the pipe or cat. I'm sure that the qualified mechanics have looked into these options, but I think they need to be re-addressed. What else could it be? It sounds like you simply have a leak somewhere...the question then becomes where? This must be driving you nuts and I hope that you can solve this mystery ASAP. Keep us posted...
  3. robiferretti
    robiferretti F1 Rookie
    Oct 31, 2003
    3,299
    NYC area
    rob ferretti
    Noah is on the verge of jumping off a bridge because of this, someone help!
  4. Dr_ferrari
    Dr_ferrari Formula 3
    Nov 2, 2003
    1,071
    Pocono Sportscar
    Jim McGee
    DAM.... that does not sound correct at all...
    What year is the 360?, Did they do the update to the cam variators?
    Sounds very much like a timing issue.
    let me know...
    Best regards, Jim
  5. W00dEar
    W00dEar F1 Rookie
    3,592
    LI, NY
    Chris
    yo yo noah, i just listened to the clip, u know what i realized??
    your car sounds like shiet zen! :D
  6. HUTCH91TR
    HUTCH91TR F1 Rookie
    Nov 7, 2003
    2,894
    Charlotte, NC
    Hutch
    I'd agree with Eric that there's probably a leak along the exhaust route. That leak is enough to keep the back pressure down, hence the muffler isn't getting the pressure/flow of air that it requires to sound as it should.
    One way to test this theory... get some soap + water (like you'd use to check a tire for leaking), and (on a cold engine!!) apply some to the headers, and along the exhaust. Whereever a bubble forms, there is a leak.
    Another theory.... bit of a reach here but worth mentioning. How are the catalytic converters? Could the ceramic honeycomb material inside of the cats be crumbling and clogging up the cats?? A chevy S-10 pickup in the wagner pools fleet started driving like ****, and sounded like it was coughing out exhausts. The catalytic converter's honeycomb ceramic material had crumbled and broken, and that was the cause of the ****ty performance. I had the fun of ripping the catalytic converter off and installing a new one. That s-10 had 90k miles and was about 4 years old.
    Best of luck in solving this!
  7. noahlh
    noahlh Formula 3
    Aug 28, 2003
    2,231
    NYC, NY
    Noah
    Car has straight pipes, so no cats...:(
    nlh
  8. noahlh
    noahlh Formula 3
    Aug 28, 2003
    2,231
    NYC, NY
    Noah
    Jim --
    The car is a 2000 Euro model....and I don't believe they updated the cam variators.
    Other people have suggested timing as a problem, and it's something I'd like to look into. The frustrating part is that the shop that did the work is INSISTING that the timing is now perfect and to factory-spec, and they even suggested that my car is correct while all the other cars I refer to (that sound good) have timing set way off. ("Everybody's lost but me!").
    nlh
  9. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Take that Puppy to someone who know's what their talking about. Kevin/Rosario at WWOC or Lugui or Chaca at Long Island. Mention my name.
    If the variators go it's a BIG BILL.
  10. Black355
    Black355 F1 Veteran
    Feb 3, 2004
    5,255
    10036
    Emil
    Note: Jim refers to "Puppy" with a capital "P"!
  11. Dr_ferrari
    Nov 2, 2003
    1,071
    Pocono Sportscar
    Jim McGee
    Ask the dealer who did the work if they have a SD2 printout of the engine management system at the time of the repair. You can check the cam angle of the variator and at least may give you a clue before a full check of the cam timing. It is very possible the cam timing is incorrect or you have a failed variator.
    Cam timing should read as 657 on the sd2 printout.
    max being about 659 minimum being about 655.
    If they cannot provide, I suggest send to WWoC for a check. ask for justin or kevin.
    best regards, Jim
  12. robiferretti
    Oct 31, 2003
    3,299
    NYC area
    rob ferretti
    Cam timing was checked today
    left side 647 right side 667
    guess we found our problem
  13. ghost
    ghost F1 World Champ
    Dec 10, 2003
    10,046
    Singapore
    Glad this is close to being resolved.
  14. TOM B
    TOM B Formula 3
    Jul 24, 2003
    1,038
    Orange County, NY
    Thomas Buckley
    And where was this 30K service done ? Inquiring minds want to know....so we can avoid this facility. TIA
    Tom
  15. Hubert888
    Hubert888 F1 Veteran
    5,441
    Manhattan & LA
    Hubert
  16. robiferretti
    Oct 31, 2003
    3,299
    NYC area
    rob ferretti
    Just an FYI this is the first such mistake that I have heard of from FOCNJ. They are all stand up guys there and I am sure they will fix the timing problem, keep in mind everyone makes mistakes. Its how they fix the mistake that keeps people coming back. I would reccomend FOCNJ any day of the week, they are all courteous and friendly people operating an excellent Facility.
  17. HUTCH91TR
    HUTCH91TR F1 Rookie
    Nov 7, 2003
    2,894
    Charlotte, NC
    Hutch
    Here's a kleenex to wipe your nose off, Rob...
  18. udalmia
    udalmia Guest
    well said, and noah was telling me last night they did a great job on everything else and the car was running better than he bought it, cant really be busting focnj's balls if they are willing to fix it, theyre just finding their legs
    ive used focnj twice, once to fix a door clip (passenger door wouldnt open) which they fixed under warranty, checked out the CE light codes, about 2 hours of work total, all under warranty, second time, car picked up, battery replaced, disk brake software updated, car dropped back, all under warranty
    it is very very satisfying to receive a bill of $0 from a F-car dealer, its something you dont see everyday, and i saw it twice
  19. Buttuz4eva
    Buttuz4eva F1 Rookie
    2,717
    LONG ISLAND N.Y.
    Challenge Farrelle
    i dont think it sounds so bad?
    sounds mean with all the popping keep it
  20. Diablo
    Diablo Formula Junior
    So did FOCJ fix the problem???
  21. Diablo
    In my opinion the best mechanic can work out of a van.
    You can put anyone in a fancy dealership and spit you technical BS when they can't fix the damn car.
    Bottom line, you have to get the job done right the first time.
    That's why we pay the big bucks for service.
  22. Hubert888
    5,441
    Manhattan & LA
    Hubert
    couldnt agree more zen!
  23. MARBELLO
    MARBELLO Rookie
    Jan 7, 2005
    8
    WHO DIAG. THE PROBLEM?
  24. TOM B
    TOM B Formula 3
    Jul 24, 2003
    1,038
    Orange County, NY
    Thomas Buckley
    AMEN !!!!!!!!!!
  25. notoboy
    notoboy F1 Rookie
    Jul 8, 2003
    2,531
    NYC
    David
    Noah,
    So you get it fixed yet???
    Did you try Auto Sport Design? They may not be cheap, but they'll probably find and fix the problem. They fixed my 355 when no one else could even figure out what the problem was after many visits to dealerships.
