Help Mondial T valeo issue | FerrariChat
Discussion in 'Australia' started by MMT, Jan 6, 2016.
  1. MMT
    MMT Karting
    Apr 3, 2014
    80
    Australia
    Michael
    Hi All
    I'm located in Sydney and new owner of 1992 Mondial T with Valeo clutch system, as I don't real know who to take it to, I have made few phone calls and no one seems to give a straight answer, I was hoping if anyone who might have similar type of car and able to direct me to Ferrari workshop who has SD1 and Valeo program to diagnose issue with hard gear selection, even if I have to ship it to Vic, QLD its ok,.
    Thank you, all in Advance
    Michael
  2. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Congrats on the Mondial mate. Any pics?
    Hopefully someone can point you in the right direction in regards to finding someone whom can work on it.
    Have you done a search for Mondial T Valeo issues? There is a wealth of information from long term Mondial owners in the Mondial section.
    They might be able to offer some advice or checks you can perform yourself in regards to the hard gear selection while you wait to have the car looked at by a professional.
    It could be something simple you can do yourself.
  3. wrxmike
    wrxmike Moderator
    Moderator Owner
    Mar 20, 2004
    7,674
    You have a PM
  4. ButchFoord
    ButchFoord Karting
    May 3, 2014
    116
    Aaron (Butch)
    If I'm not mistaken, I seem to recall that the factory service bulletin from Ferrari HQ for valeos was to replace them with the 5 speed manual.
  5. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
    Ouch!
  6. carl888
    carl888 F1 Veteran
    Oct 31, 2003
    6,945
    Carl
    There is no difference in transmissions between the Valeo and the standard 5 speed unit in the Mondial T. The difference is in the clutch actuation only. There is an electro mechanical sensor on the gear selector which actuates the clutch.
    With only 2 Australian delivered Valeo Mondial T vehicles plus a nominal number worldwide you'll have your work cut out for you finding a motivated service person here. My advice would be to purchase the Valeo workshop manual (It's a supplement to the standard Mondial manual) and I start checking the electrical side first. It's not S.S. old car is it? Good luck.
  7. moretti
    moretti Five Time F1 World Champ
    Nov 1, 2003
    59,757
    Australia
    #7 moretti, Jan 7, 2016
    The Valeo that was up here was serviced by Chris at John Cant's, but that was back in the dark old days.
    Here is a photo of it when John Cant was still alive ...... 17th January 2002
  8. MMT
    MMT Karting
    Apr 3, 2014
    80
    Australia
    Michael
    Hi Carl , you are spot on , gear box clutch all same, just the valeo has ecu to plug into so able to diagnose and operate the system, sorry mate I didn't catch on ((It's not S.S. old car is it.))
    Cheers
    Michael
  9. MMT
    MMT Karting
    Apr 3, 2014
    80
    Australia
    Michael
    Mate, it wouldn't surprise if that was the same car it looks identical, if you know anything about this car feel free to sent me private message if you like.
    Sorry to hear About john ..
    Cheers
    Michael
  10. ihavearedferrari
    ihavearedferrari F1 Rookie
    Nov 23, 2007
    3,316
    Adam
    What are Mondial Ts worth these days if you dont mind me asking?
  11. Frari
    Frari Formula 3
    Nov 5, 2003
    1,194
    brisbane australia
    tony
    Hi Michael, was my car til I went up to nth QLD . I have spoken to you after you bought at auction. The problem is the sd1 does not work with the valeo as it is an ms dos system or so Keith minchen ex service manager of cants and euro marque told me a few years ago .it is an actuator driven clutch motor that depresses the clutch. If this is working correctly then I would suggest maybe your gear linkages may need attention as all it does is engage and disengage the clutch just like your foot and is matched to revs. I used to lose gears from time to time as the micro switches in the gear lever area were a bit unreliable due to age. There was a club member in sydney or maybe melbourne who ran a valeo as a wedding car he had a good knowledge of how they worked and some good fixes. He also had some instruction on how to recalibrate the ecu learning by a number of stop starts at various revs. I can not remember his name however someone on this forum will.
    I enjoyed it but hated the 'what's going to happen next" feeling every time I took her out so I was looking at turning her back into a standard manual. The cost .. About 5k would solve all these problems in the future as I also could find no one who knew what they were doing or who had the correct equipment.
    Chris at automotion Brisbane did some work for me he may be able to help
    My understanding is micro switch picks up movement in gear lever actuates clutch. Ecu picks up the revs and matches clutch movement to revs i.e. How fast or slow it releases.
    The clutch actuator is bolted to the bell housing and there is an adjustment screw for travel. The solenoidsare in the rear trunk behind the carpet at the top I think there are 5 ,1 for each gear.
    I think if you can get a manual and the ms dos floppy for the valeo you may do better or maybe a talented valeo truck shop mechanic may be able to help as this system was also used in Lancias and many trucks. Otherwise it is a bit of guess work and a black art, a bit like refrigeration;) . Hope this helps I gave you my number a year or so ago but pm me if you want any help.
  12. PAP 348
    Dec 10, 2005
    100,220
    Pap
    #12 PAP 348, Jan 9, 2016
  13. Frari
    Frari Formula 3
    Nov 5, 2003
    1,194
    brisbane australia
    tony
    Fark.��
  14. simon klein
    simon klein Two Time F1 World Champ
    Feb 25, 2009
    29,801
    North Qld
    simon klein
    Sh$t,that's a shedload of damage..what's the story,morning glory?
  15. PAP 348
    Dec 10, 2005
    100,220
    Pap
    That's one of the cars used to do weddings back in the day in VIC.
    That accident was in a roof top shopping centre carpark.
    Accelerator stuck on apparently and the driver/owner crashed the car into the wall.
    Had the bride and groom in the back too, I think they all sustained some injuries but walked away. Maybe the Wife had broken some bones, I think. Going back nearly 10 years now this accident.
    The owner was trying to sell the business and two Mondials at the time from memory. I think this crash happened when I first joined the forum, so it would be around or just over 10 years ago.
    I also think 360C knew the owner or the car from some club runs?? Or it's his mate, can't remember 100%.
  16. MMT
    MMT Karting
    Apr 3, 2014
    80
    Australia
    Michael
    HI Tony
    Good to hear from you again, thanks for the info, if you have phone number for Chris at automotion Brisbane, it would be handy,
    Cheers Michael
  17. Frari
    Frari Formula 3
    Nov 5, 2003
    1,194
    brisbane australia
    tony
    07 38551644
  18. Frari
    Frari Formula 3
    Nov 5, 2003
    1,194
    brisbane australia
    tony
    Accelerator stuck... Don't you just turn off the ignition key. Melbourne mafia ..? Mob hit? Just joking turning off ignition would surely minimize damage plus foot on brake. You can see the wedding ribbons still hanging on the car.:(
  19. IanB
    IanB F1 World Champ
    Jun 15, 2006
    16,225
    You should dip the clutch, then kill the ignition. Unfortunately 99% of drivers panic and put all their effort into braking, but the engine of course is more powerful than the brakes.
  20. moretti
    Nov 1, 2003
    59,757
    Australia
    I thought that would be instinctive ?
    But I can imagine how people would panic
  21. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,220
    Gold Coast, Aust.
    Patrick
    Had it happen to me in the Esprit Turbo. Accelerating up to an intersection in second, was going to leave it in second, hit the brake and the car kept accelerating - horrible feeling. Both front wheels locked up with the car still under power. It probably took me a second to turn off the ignition, but seemed like forever. Idiot mechanic, now out of business.
  22. Andy 355
    Andy 355 Formula Junior
    Jun 2, 2013
    434
    hmm i think you might find the brakes can generate LOTS of hp.... Way more than that engine could dream of....
  23. IanB
    IanB F1 World Champ
    Jun 15, 2006
    16,225
    Find an empty road and test your theory.... then get back to us.
    In the days of slide injection, quite a few good drivers died in stuck throttle accidents.
    btw Anyone with an older Ferrari should renew the accelerator cable the minute it starts to fray.
  24. IanB
    IanB F1 World Champ
    Jun 15, 2006
    16,225
    I had a carby specialist fit a big double pump Holley to my '65 Mustang, out in the traffic it stuck open the first time I floored it. Very glad I had electronic ignition with a rev limiter, dipping the clutch was the only way to avoid rear ending someone.
  25. Aircon
    100,524
    Peter
    since when has that been a priority for you?
