HELP!!!! NEED EXPERT ADVICE on 355 F1 Unit!!! | Page 2 | FerrariChat
Discussion in '348/355' started by TTG, Apr 23, 2013.
  1. WATSON
    23,939
    WI
    I have a 360 pump and my cycle time at start up is 8 flashes. Pretty sure it is not a problem. Perhaps I am wrong?
    That spinning sound isn't the radiator fan by chance is it?
  2. TTG
    TTG Formula 3
    Jun 11, 2002
    1,555
    East Hanover, NJ
    Todd Gieger
    Yes. The accumulator was not holding the pressure so the pump would keep trying. The 360 accumulator didn't fit on the 355 F1 so Daniel at Ricambi just ordered the fittings that should make it work...I am hopeful that by early this week this will be resolved. Here's Daniel's contact info if you have questions...REALLY cool guy and REALLY knowledgeable.
    Daniel Pass
    Ferrari, Maserati, Lamborghini Parts - Ricambi America, Inc.
    tel (336) 499-2500
    fax (866) 596-0043
  3. Labman
    Labman F1 Rookie
    3,803
    Long Island, NY
    Steve
    8 flashes seems a bit much for a 360 pump. Mine only flashes about 2-3 times only at cold start. At a gas station I have no wait time.
  4. ToddB
    ToddB Formula 3
    Nov 4, 2003
    2,241
    Vancouver B.C./OC
    Todd
    Daniel helped ferrari of vancouver fit the 360 unit on my 355 fiorano. I believe a few brackets and a hose were fabbed up but it was a cheap fix overall
  5. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    We Ferrari owners are incredibly fortunate to have Daniel and Ricambi. I don't see how it would be possible for a company to provide better customer service. Moreover, one does not have to be concerned with gaff parts (which is a major problem in the industry) when you purchase them from Ricambi.
    Thank you Daniel for all that you do.
  6. TTG
    TTG Formula 3
    Jun 11, 2002
    1,555
    East Hanover, NJ
    Todd Gieger
    Ferrari of Central Jersey got the 360 Accumulator to fit on my 355 Fiorano with some fittings but now the pressure is reading way to high...Charlie at F of Central Jersey is going to post here shortly to further explain
  7. phrogs
    phrogs F1 Veteran
    7,361
    Kzoo Michigan
    Get a stand off fitting to take up the difference. What is so hard about that?
  8. Ricambi America
    Sponsor Owner
    Nothing.
    That's what was supplied. The problem is not about fitting parts together, unfortunately.
  9. ChuckStyl5
    ChuckStyl5 Karting
    Mar 28, 2004
    180
    The Armpit
    The accumulator was fitted with the adpater and that worked great. The issue we are having and the code we are getting is that the hydraulic pressure value is too high. The pressure is reading upwards of 80 psi. We have swapped over other pressure sensors and get the same reading. The pressure with ignition on is 50 psi but when driving goes as high as 80. Might it be the pump? Maybe but also maybe the internals of the power unit because when you adjust the pressure/bleed screw the hydraulic pressure does not change. Anyone else have any possibilites with selling an entire F1 kit?? That he what we are trying to stay away from. Any suggestions are appreciated.
  10. TTG
    TTG Formula 3
    Jun 11, 2002
    1,555
    East Hanover, NJ
    Todd Gieger
    PLEASE SOMEONE HELP....There is NO friggin way I am spending my kid's college tuition for an entire F1 unit for my 355. Please call me with any suggestions at 973/294-8500
  11. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    I have the standard 355 pump, OEM, never changed. At a cold start, my light flashes exactly 7 times, always.
    If I stop for a few mintues, I get zero flashes when I re-start.
    Sometimes the next day I get only 2-3.
  12. WATSON
    23,939
    WI
    I am still confused as to the need to swap the accumulator. Was it leaking?
    What is the operating PSI or BAR of the 355 pump? 360 pump? Are they the same? I have no idea.
    What does the SD computer show as errors?
    The hydraulic function of this system is fairly straight forward. Bleed out the air and make pressure....
    The electrical / ECU side is where the "magic" happens.
  13. WATSON
    23,939
    WI
  14. TTG
    TTG Formula 3
    Jun 11, 2002
    1,555
    East Hanover, NJ
    Todd Gieger
    This is REALLY REALLY REALLY frustrating!!! There HAS to be someone at Ferrari HQ that knows how to fix this without buying an entire F1 unit!
  15. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    I agree.... I hope you find the answers you need sorry I don't have them.
  16. WATSON
    23,939
    WI
    Tough when it does not work. Wish you were closer as I think I could help.
    Mine was a mess after the "mechanic" got a hold of it.
    I sorted the mess out and it works great now...save for one more hydraulic line change.
    But I feel your frustration. Been there done that.
  17. Labman
    Labman F1 Rookie
    3,803
    Long Island, NY
    Steve
    Ask Dave Helms maybe?
  18. WATSON
    23,939
    WI
    Bradan is in your neck of the woods. He has an SD computer as well. Might be a more local solution.
    I'll say it....I think the advice you are currently getting from your service center of choice is not ideal.
    Call Dan at Bradan.
  19. TTG
    TTG Formula 3
    Jun 11, 2002
    1,555
    East Hanover, NJ
    Todd Gieger
    Sorry but who is Dave Helms? Do you have his phone or email?
  20. TTG
    TTG Formula 3
    Jun 11, 2002
    1,555
    East Hanover, NJ
    Todd Gieger
    Can you give me "Dan at Braden's" contact info...I am unfamiliar with him....THANKS SOOO much guys!
  21. Monteman
    Monteman Formula 3
    2,348
    Santa Barbara, CA
    Monte
    Scuderia Rampante. One of the best 355 guys in the country and the creator of several solutions to known problems. Located in the Denver area.
    Scuderia Rampante Ferrari
  22. WATSON
    23,939
    WI
    Bradan is an independent maintenance facility. His company specializes in higher end sports cars.
    Dan has personally talked me through an F1 issue I had despite me being 1100 miles away. He has seen a lot of 355's.
    Bradan is a great group. Dan is a great guy...and better yet they are a sponsor of this site.
    Website: Bradan Group, LLC
    Phone: (631) 585.8600
  23. Labman
    Labman F1 Rookie
    3,803
    Long Island, NY
    Steve
    Any update on this?
  24. TTG
    TTG Formula 3
    Jun 11, 2002
    1,555
    East Hanover, NJ
    Todd Gieger
    Ferrari of Central Jersey has had my car since March 8th and it's still not fixed...I am at my wits end now!
  25. Wolfgang5150
    Wolfgang5150 F1 Rookie
    Oct 31, 2003
    4,706
    Bump? Any update - these kinds of things scare the crap out of me. Hope it's working out for you.....
