Help need !Ferrari 458 Immobilizer Malfunction | FerrariChat
Discussion in 'Technical Q&A' started by Kelson Say, Aug 16, 2018.
  1. Kelson Say
    Kelson Say Rookie
    Jun 17, 2018
    17
    Kwee chuen Say
    Dear all members of Ferrari Chat
    I have encountered an issue with my ferrari 458 italia 2010
    Every time when i start the car , the immobilizer malfunction warning sign keep comin on .
    I need to turn on and off a couple of times before then the immboilizer malfunction is gone n then i can start the car .
    Sometimes even other warning signs comes out n disappear eventually after i turn on & off with the keys .
    I have send in to the dealership n they told me this was the first case .
    Now they are talkiing to the ferrari factory to hope to get some solution to this issue.
    And at the same time i would look out for some answers that some of the members here may have experience such issue or has any suggestion to my this issue .
    I have try 2 keys but both has the problem too .so dont think is key faulty
    Anyone here has ever encountered this problem with their ferrari 458 italia
    Please share with me here on this chat .
    Thanks for reading n Have a Good day !
  2. Cribbj
    Cribbj Formula 3
    I have no knowledge of the 458 as I am a 550 Maranello owner, but ALL Ferraris have electrical gremlins. Here are some suggestions based on issues encountered with earlier models:
    1. Do not start the car immediately, give it a few seconds to "learn" that you're in the car before turning the ignition on and starting.
    2. Lots of issues with poor grounding and batteries that aren't fully charged. Check your battery cables for tightness & corrosion, and see if your battery will pass a "load" test.
  3. Kelson Say
    Kelson Say Rookie
    Jun 17, 2018
    17
    Kwee chuen Say
    Thanks for info n yr response .Have a great day !
  4. cyljpn
    cyljpn Rookie
    Jun 11, 2020
    3
    masaki shishido
    Hello Kelson
    My 458 is in exactry the same situation, did u solve that?
  5. brogenville
    brogenville Formula 3
    2,020
    Robin
    Be helpful if you scan the body ecu to read the fault code. Could be something as simple as a faulty antennae in the steering column.
  6. cyljpn
    cyljpn Rookie
    Jun 11, 2020
    3
    masaki shishido
    Hello brogenville
    Thanks for your info, I will check for that!
  7. Teamrjo
    Teamrjo Rookie
    Aug 31, 2020
    1
    Ron Jeriel Ong
    Were you able to fix the Immobilizer malfunction on your 458? I am experiencing the same problem with my 2011 458 Italia.
  8. windsock
    windsock Formula 3
    1,070
    Ensure you have no other RFID devises on your key chain. Gate fobs, office fobs even other keys from other brands can corrupt signals. rule out the external concerns first. The antenna is located around the ignition tumbler and the chip is in the key.
  9. Qavion
    Qavion F1 World Champ
    11,556
    Ian Riddell
    Does the 458 suffer from the same antenna problem as the 430? There was a fix on YouTube
  10. windsock
    windsock Formula 3
    1,070
    I have never seen an antenna fail or have issues. It has always been a damaged key or external interference.
