Help Needed - 348 Starting Problem | FerrariChat
Discussion in '348/355' started by Siban, Dec 3, 2006.
  1. Siban
    Siban Rookie
    Aug 20, 2004
    13
    Help needed please guys.
    I've just taken the battery out of my '93 348 to recharge it and now it's back in I can't start the car.
    When I turn the key to start I get a fast 'click-click-click' from the engine bay which sounds like a relay. Battery seems fully charged.
    Hopefully this will sound familar to somebody. Had the car since 2000 and never had this before.
  2. PeterS
    PeterS Five Time F1 World Champ
    52,160
    Goodyear, AZ
    PeterS
    Why take the battery out of the car for a re-charge? You battery probably needs to be replaced. Cheap troubleshooting for $80 IMO.
  3. Siban
    Siban Rookie
    Aug 20, 2004
    13
    I'd run it low as I'd left the interia light on....not going to buy a new battery just because of that.
  4. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    A fast "click-click-click" indicates that the battery is too weak to operate the starter. Do you have a voltmeter to check the battery? Do you have some jumper cables? Do you have a good battery from another car that you could install as a test? I'd say that there is about a 98% chance that the battery is your problem. It might still take a recharge, but if it's more than three or four years old, just replace it. It's not worth having it cr^p out when you are away from home.
    Edit: Of course you need to make sure that your battery connections and cable connections are clean and tight, but if they were OK before you ran the battery down, they are probably OK now.
  5. PeterS
    52,160
    Goodyear, AZ
    PeterS
    Kragen can do a REAL fast check on the functionality of your alternator. That may be your problem if you battery is draining fast.
  6. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    The battery may seem fully charged, but it may have dropped a cell. Get someone to put a voltmeter across the battery terminals as you crank the car and see what the voltage reads while cranking. Anything under 10volts is sluggish and nearing 9volts you may as well throw the battery away. Yours will be the latter I think. :)
  7. Siban
    Siban Rookie
    Aug 20, 2004
    13
    Thanks very much the responses guys
  8. fatbillybob
    Aug 10, 2002
    29,021
    socal
    Yup...+1
    The click is the solinoid to the strater motor not getting proper juice. Check your grounds/connections. Load test the battery.
  9. Siban
    Siban Rookie
    Aug 20, 2004
    13
    Just wanted to say Thanks and you were all spot on......new Battery did the trick
  10. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Good to hear!! :):)
