Help Needed - 355 Convertible Top | FerrariChat
Discussion in '348/355' started by DCFerrariGuy, Apr 10, 2007.
  1. DCFerrariGuy
    DCFerrariGuy Rookie
    Aug 27, 2006
    5
    I have a 95 355 spyder whose top is not functioning. Any recommendations for a local guru in the Washington DC/Northern Virginia Area?
  2. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Does it make any noise at all??? It may just need Hydraulic fluid, very easy to do unless you like to spend money at the dealer :eek:.
    Here is a step by step post by my good friend and fellow F355 spider owner chaa posted:
    http://www.ferrarichat.com/forum/showpost.php?p=136278178&postcount=25
  3. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    What are the symptoms?
    Have you tried the emergency override button?
    355 tops typically "fail" when the pots in the seat tracks give up, or when the relay for the system dies, or when low on hydraulic fluid, or when the top cross-bar gets stuck down.
  4. Ricambi America
    Sponsor Owner
    #4 Ricambi America, Apr 11, 2007
  5. spectralcodec
    spectralcodec Rookie
    May 14, 2007
    1
    I had to fill the hydrauic fluid reservior on my 355, does this indicate that there is a leak?
    Chris
  6. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    I don't think so. I had to 'top mine off' too and I do not see a leak anywhere...... I don't know what happens to it :confused: !!
  7. markcF355
    markcF355 F1 Rookie
    Jun 6, 2004
    3,493
    Schmeckelstan
    Mark
    Where that oil goes is one of life's great mysteries.
  8. f355spider
    f355spider F1 World Champ
    18,047
    Unlikely. Seems some cars (mine included) require occaisional "topping off". Mine will go from the "max" line to the "min" line in 18 months or so... No visible or active leaks found...I have a couple friends 355 spiders that do the exact same thing. Then again, I know a couple others that seem to never lose a drop! :)
