Help needed about european 328 | FerrariChat
Discussion in 'Europe' started by F328GTS/GTB, Oct 4, 2005.
  1. F328GTS/GTB
    F328GTS/GTB Formula Junior
    May 3, 2005
    517
    France
    Denis
    Hello guys,
    Does any one know if there is specification differences between european 328 ? Mainly, do belgian cars have own specifications ?
    Background is: if I buy a 328 in Belgium or Germany, could I have some troubles to maintain it in France ?
    Thanks for your advices !
    Regards
  2. rpmtifosi
    rpmtifosi Formula 3
    Nov 5, 2003
    2,467
    Belgium
    Guy
    Don't think there will be any major differences! Surely no technical differences!!
    Good luck with the search!! :)
  3. Dutchman
    Dutchman F1 Veteran
    Dec 4, 2002
    6,184
    EU
    Ton
    No!
    There is no difference between the European Ferrari's. Only the cars imported from Switzerland can have a different configuration.
    So, the answers will be No, no, no. :)
    Ton
  4. alx355gt
    alx355gt F1 Veteran
    Feb 3, 2004
    9,524
    Belgium
    Alexander
    I also think there aren't huge differances between Euro-spec cars.
    The yellow front headlights rule in France is long history no?
    Good luck in finding your Ferrari!
  5. F328GTS/GTB
    May 3, 2005
    517
    France
    Denis
    Thanks for your reply that confirmed my idea.
    I keep looking for a red 1988,5/1989 328 GTB...
    Regards,
  6. hedge
    hedge Formula 3
    Jun 11, 2003
    2,320
    England
    Marc
    Not to my knowledge..thought all euro specs were the same, just U.S different?
    Good luck though - wonderful machines.
  7. jbanzai
    jbanzai Formula 3
    Feb 1, 2002
    1,564
    Madrid, Spain
    Julio
    Swis and US are similar, the main difference was these cars have a Cat exhaust, where both exhaust heathers converged into a single Cat and then to the muffler. These also include a Air injection system into the exhaust and differences on the CPU to control the mix through a lamda and thermocoupler in the CAT.
    The european version exhaust was way simpler, the 2 exhaust headers go into the muffler one on each side of it, with no Cat, with no thermocoupler, and no exhaust air injection system.
    So the Euro version produced 270 HP compared to the 256 of the Swis and US versions.
    - Julio.
  8. Dutchman
    Dutchman F1 Veteran
    Dec 4, 2002
    6,184
    EU
    Ton
    Why do you want an ABS model?
  9. Simon
    Simon Moderator
    Moderator Owner
    Aug 29, 2003
    6,876
    Switzerland
    Simon
    As far as I understand there are no exahust air pumps on fuel injected cars.
    This was only for the carb cars where there are higher levels of unburnt fuel in the exhaust.
    The US and Swiss having cats is right, but they also have upgraded rear suspension as the old pre 89' didn't leave enough space for the catalyst.
    Cheers
    Simon
  10. jbanzai
    jbanzai Formula 3
    Feb 1, 2002
    1,564
    Madrid, Spain
    Julio
    #10 jbanzai, Oct 5, 2005
    They do not have an air pump, they have a pipe that diverts from the airbox that goes to 2 small pipes that runs along the headers with small pipes into each individual exit. This air is injected into the exhaust to help burning the remaining unburn gas before reaches the cat. I know this in detail, as it broke on mine and I fixed it myself. (because this is easy...)
    First one is the USA Air injection sytem, the second one is the Swis version.
  11. Simon
    Simon Moderator
    Moderator Owner
    Aug 29, 2003
    6,876
    Switzerland
    Simon
    Thanks. You're right. I was thinking of the old air pumps on US carb exhausts.
    Cheers
    Simon
