Help needed: AC fan only running on high | FerrariChat
Discussion in 'Mondial' started by americanpaki, May 21, 2014.
  1. americanpaki
    americanpaki Rookie
    May 21, 2014
    2
    I have a 1989 t and my AC fan only runs on high. If I turn the fan dial to the middle, it does not run. But if I press the A/E button then it runs on slow as well as high. When AC button is pressed the fan comes on only when I turn the dial to max (high). Any ideas as to what could be causing this?
    I tried to run a search but did not find anything specific to this topic. Maybe didn't run the search properly but if anyone can tell me what could be the cause or point me to a thread that has this top I would greatly appreciate it.
  2. bartzagato
    bartzagato Formula Junior
    Aug 7, 2010
    614
    Belgium
    Bart
    #2 bartzagato, May 22, 2014
    Hi
    If only 2 things work: off or full speed: regulators are broken. I don't know how the Mondial T is in this department, perhaps it has a potentiometer in the fanspeedknob as the QV: n°7.
  3. raf456
    raf456 Karting
    Jan 27, 2013
    178
    Chapel Hill, NC
    Robert Freiburghouse
    I had the exact same problem. My mechanic replaced a transistor somewhere in the system because the fan speed unit #8 in the diagram was not available. I will ask him exactly what type of transistor and where he put it.
  4. americanpaki
    americanpaki Rookie
    May 21, 2014
    2
    So the question is that if the transistor is bad will it still work with A/E but not with AC button? Did you have the same problem where it was working fine when A/E was pressed but not when AC was pressed?
  5. raf456
    raf456 Karting
    Jan 27, 2013
    178
    Chapel Hill, NC
    I don't recall if the failure was only when AC was pressed - I think that it failed with either.
  6. Mondial 1985
    Mondial 1985 Formula Junior
    Jun 13, 2012
    344
    Greenville, SC
    Mark Alan Day
    You mean yours runs?
  7. Rapalyea
    Rapalyea Formula 3
    Jun 18, 2013
    1,511
    Georgia Mountains US
    David Rapalyea alias
    Mine is intermittent. I do not have A/C but love the strong fan. Except when it does not run at all. This morning it ran fine until I stopped to shop. Then did not run again for the rest of the day.
    Its not all that big a deal where I live. Today is hot at about 90F but always low humidity. Both windows down and the sunroof opened about six inches and the general air flow is very good. But when stopped [which is rare enough] I do miss the vent fan.
  8. Daniel789cars
    Daniel789cars Rookie
    Sep 13, 2005
    11
    Las Vegas
    Dan
    I know I am late to reply, but did you ever find out what your mechanic did, as my car is having same issue.
  9. Steve Magnusson
    26,861
    What model/year/version F? If a TR, as in your Profile, do a search in the TR section using "power transistor" for many prior threads. The stock TR location is riveted inside the center air outlet vent (the idea being to use the air coming out of the center vent area to cool the transistor), but sometimes people move it to another location.
  10. Sigmacars
    Sigmacars Formula 3
    1,220
    This is the Transistor you need on e bay $5.00 it regulates the fan speed
