Help needed - Door adustment 550 | FerrariChat
Discussion in 'Technical Q&A' started by rmfurzeland, Nov 25, 2007.
  1. rmfurzeland
    rmfurzeland Formula Junior
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    I am having problem with the passenger door on my 550 , the inner door edge is scraping on the back edge of the fender when I open it. Anyone know the correct way to adjust it, I have tried loosening the 13mm bolts on the door hinges and readjusting but it is now worse. I have used 2 small jacks to take the weight of the door. The door needs to go back towards the rear especially in the bottom area.
    What is the trick to do this?
    Thanks.
    Ron
  2. darth550
    Jul 14, 2003
    61,183
    In front of you
    BCHC
    Is the little latch tight?
  3. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    Which little latch do you mean? The center hinge with a pin in it that stops the door from opening too far?
    I have tried loosening this one a bit , not all the way though
    Ron
  4. darth550
    Jul 14, 2003
    61,183
    In front of you
    BCHC
    The one the door fastens to towards the back. Mine came loose and the door sagged as you described. 2 bolts.
  5. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    No the rear latch is fine, door opens OK,
    problem is how to adjust the front hinges such that front of door doesnt touch bodywork..?
    Thanks,
    Ron
  6. darth550
    Jul 14, 2003
    61,183
    In front of you
    BCHC
    Gotcha... You know, Dave, over here at Premier Motorsport is one of the nicest guys on the planet. If you call him tomorrow, and he has a minute, he will help you..
    310-559-1562. Just tell him the entire SoCal section of Ferrarichat sent you! LOL! :):)
  7. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    Thanks for the tip, very helpful and knowledgeable people at Premier Motorsport, they advised adding an extra shim to the lower hinge, between the hinge and the door.
    I will try this out,
    Regards,
    Ron
  8. darth550
    Jul 14, 2003
    61,183
    In front of you
    BCHC
    I'm glad they were helpful and I hope it works... :)
  9. darth550
    Jul 14, 2003
    61,183
    In front of you
    BCHC
    Did it work? :)
